Thread: Setting up PS2 so it works! |
| Posted on Sunday, May 23, 2004 - 11:09 pm: |
I've just bought a PS2 for my daughter's 11th birthday but am having trouble making it work. Connected thru the TV all I get when I turn it on is a black screen with white flickering writing down the middle. I think it says enter but it isn't easy to make out. I've double checked all the connections. I think it may be something in my TV which is about 8 years old. It doesn't work at all connected thru the VCR. I'd really appreciate any help you can give me. |
Silver Member Username: Project6
Post Number: 595 Registered: Dec-03
| Posted on Thursday, May 27, 2004 - 11:11 am: |
do you have audio inputs at the back of your tv? |
Matt Whitesides Unregistered guest |
| Posted on Thursday, June 17, 2004 - 02:04 am: |
did u hook up the red with the red and white with white... ect and put the tv on video mode really if u did all the plugins and make sure the connections are in the slot good then its eather the ps2 or tv i dont think u are but if u are useing componet cables and u miss macth the green adn blue the same kinda thing happens or it did to me but the av jacks on some old tvs can get jacked up after a while |
| Posted on Thursday, July 29, 2004 - 03:22 pm: |
i pluged the whight one and the red one in to my vcr |
| Posted on Tuesday, August 10, 2004 - 08:44 pm: |
How come my PS2 wont even het power; (the little red light wont turn on) HELP?!?!?!?!?!?!?!?!?!?!? |
undercover brother Unregistered guest |
| Posted on Thursday, August 26, 2004 - 12:02 am: |
because its probibly broken |
New member Username: Feicstur
Chicago,
Illinois
Post Number: 2 Registered: Aug-04
| Posted on Thursday, August 26, 2004 - 03:27 pm: |
CCOO, Make sure the polarity on the plug in the back of th unit is accurate. This means that the round part and block part are on their respective sides of the port. if your plug is round on both parts try switching them. Second try plugging the device into another outlet. Check to see if it's over heating. If that doesn't fix it "its probibly broken" |
POKEMON KID Unregistered guest |
| Posted on Tuesday, August 31, 2004 - 12:36 am: |
_,,,,_ _ww_ /""""\ (o) (o) / o o \ ! o o ! / () \ ( ! O ! ) ( ! () ! ) \ __ / \ _ / \ __ / .
| Posted on Tuesday, August 31, 2004 - 12:39 am: |
Wow... Cool pic |
Post Number: 1274 Registered: Dec-03
| Posted on Tuesday, August 31, 2004 - 06:14 pm: |
yay! |
Berny....one question ? Unregistered guest |
| Posted on Wednesday, September 01, 2004 - 05:42 pm: |
how many posts do u have to post to become a gold member ? |
New member Username: Jay_dub
La
United States
Post Number: 10 Registered: Sep-04
| Posted on Friday, September 24, 2004 - 04:22 am: |
Why wont my ps2 play most of the purple cds? |
Post Number: 1563 Registered: Dec-03
| Posted on Tuesday, September 28, 2004 - 11:12 am: |
how old is your PS2. Some won't play the blue or purple(?) disks becuase they are thinner than regular disks and you may need to thicken the center hub of the disk for it to be caught by the spinner. Some people use tape on the hub with the center punched out. |
aaaaaaa Unregistered guest |
| Posted on Sunday, October 31, 2004 - 10:09 pm: |
you need to flick the swich on in the back |
spazgammer Unregistered guest |
| Posted on Tuesday, May 24, 2005 - 07:37 am: |
hey cc all u need to do is take off the case of the ps2 and on the bottom theres a silvercord that connects the top cover to the input on the bottom it just prolly came out so just put it back in it might take a bit tho. |
soccer mom Unregistered guest |
| Posted on Friday, May 27, 2005 - 05:07 pm: |
RF modulator/satellite box/tv/PS2 set up too many cables - just show me a manual picture and I promise I can do it |
good times Unregistered guest |
| Posted on Tuesday, June 14, 2005 - 05:55 pm: |
i just bought my daughter a ps2 and it worked on her aunts tv with the input button but her tv doesn't have an input button but the satelite does but it still will not work what am I doing wrong HELP!!!!!!!!!!!! |
chickenlady34 Unregistered guest |
| Posted on Wednesday, November 23, 2005 - 03:11 pm: |
i can get any thing i have no input and no output how do i make it work |
| Posted on Monday, December 26, 2005 - 07:39 pm: |
at my dads house my ps2 works but at my gramas house it doesnt. in the back is 4 holes where the 3 plugs go in,i have 2taken up bythe vcr and 1 under video(yellow),1under auido(white or red ,doesnt matter)i can hear the sound but the screan is staticy.please help! |
| Posted on Monday, December 26, 2005 - 07:48 pm: |
| Posted on Wednesday, December 28, 2005 - 11:32 am: |
How do you hook up the PS2 if you have cable tv and a VCR that is hooked up to the cable tv. No connections seems to work. Do I need an RF modulator? |
| Posted on Sunday, January 22, 2006 - 06:01 am: |
How to setting back matrix for my PS2 so i can play copied games.Help!!!!! |
| Posted on Sunday, January 22, 2006 - 07:28 pm: |
How to setting back matrix for my ps2 so I can play copied games(pirated game).What is the solution!!! Please HELP!!!!!! |
| Posted on Wednesday, March 01, 2006 - 07:18 am: |
I have just got a ps2, and there are two wires, one has a red top on it and one a white top, but there are no slots to put them in!!! help! |
Post Number: 6476 Registered: Dec-03
| Posted on Wednesday, March 01, 2006 - 08:17 am: |
The red and white are your audio outputs. Youhave to connect it to the audioinputs of your TV. If you have no slots to put them in, you may want to look at an RF adapter so you can connect it to your TV. |
