Home > Message Board > Video Games > Xbox > Xbox dont work
Author Thread: Xbox dont work
Username: Astrosafari
Delhi, Ontario
Post Number: 667
little brothers friend gave my little brother an xbox, it turns on, the fan runs, but the light goes orange instead of green, nothing comes up on the screen. and the orange light flashes. its alot quieter than my xbox that works... is that because its a different model, or because all xbox's perform differently? and what do you think is wrong with this xbox?
Username: Sheriff
Post Number: 273
Usually when the LED flashes Green and Orange it means that the A/V cable is disconnected. Make sure it is plugged in right and if it is then get a new A/V cable for it and it should work.
Post:
Username: Need to Register?
Password: Forgot Password?
Action: Upload Upload Image
Home > Message Board > Video Games > Xbox > Xbox dont work [ « Previous ] [ Next » ]
