Thread: xbox 360 help plz!! |
New member Username: Spazplz
Post Number: 1 Registered: Mar-07
| Posted on Saturday, March 03, 2007 - 07:34 pm: |
ok here it is when i turn on my xbox 360 i here the noise in the background going to the main page for the 360 but my tv screen says "unusable signal", i tried buying a new AV plugs but that did not work, so if anyone can help mr plz do. |
Silver Member Username: Bigsim
NSW
Australia
Post Number: 289 Registered: Jan-06
| Posted on Thursday, March 08, 2007 - 03:32 am: |
Try changing the switch where the AV leads connect to the console, and see if that helps. |
Bronze Member Username: Emerson1
Post Number: 14 Registered: Jan-07
| Posted on Thursday, March 08, 2007 - 09:44 pm: |
On the AV cord where you plug it into the console there is a switch. One is for regular SD video and one is for component, make sure you have it set to the one that applies for you. |
New member Username: Krina37
Post Number: 1 Registered: Nov-09
| Posted on Friday, November 27, 2009 - 03:33 am: |
Hi I've tried searching the forums but struggling to get the correct info. Please can someone help. I have a pioneer 111d drive with firmware 1.23 and using clone cd to burn verbatim dvd+r dl disks but i am getting errors burning my xbox 360 backups. I believe i need to use a different firmware for the pioneer 111d drive but not sure which. Can anyone advised what the best solution is and how to do it? Any advice would be much appriciated ______________________________ burn xbox 360 games ^_^ how to burn xbox 360 games |
