Thread: PS2 on HDTV? |
Bronze Member Username: Gbelous
CT
Post Number: 23 Registered: Oct-04
| Posted on Thursday, January 25, 2007 - 09:23 am: |
Would upgrading the PS2 cables to component make a big difference in picture quality on a 1080p HDTV? |
Gold Member Username: Extrmndor3
Sit and
Look pretty
Post Number: 3464 Registered: Feb-06
| Posted on Sunday, January 28, 2007 - 09:28 am: |
yes but will be not too much only if games support progressive scan like tekken or shadow of the collosus wat u should do its go to gamestop.com and find the software that makes the ps2 upconveerts the standar or 480i resolution to 720p and i think it can go up to 1080i but not 1080p |
Sit and
Look pretty
Post Number: 3465 Registered: Feb-06
| Posted on Sunday, January 28, 2007 - 09:35 am: |
http://www.xploder.net/products/148/Xploder-HDTV-Player.htm |
CT
Post Number: 27 Registered: Oct-04
| Posted on Monday, January 29, 2007 - 09:26 am: |
Do they have any sites in the US to sell this? What exactly is it and how does it work? |
Sit and
Look pretty
Post Number: 3546 Registered: Feb-06
| Posted on Wednesday, January 31, 2007 - 07:26 am: |
yes they sell it i saw it at gamestop it was 50bucks. but its better you get it str8t from the company. u insert the disk and it will it will say some options on resolutions outputs you only will chose the resolution you want the ps2 to produce and thats it u remove the disk and insert your ps2 game thats it. |
New member Username: Sparkymark
Cardiff
Post Number: 1 Registered: Feb-07
| Posted on Friday, February 23, 2007 - 05:21 am: |
Hi Mr Rob, I've got a Samsung 32 inch Flatscreen HDTV and I've just got those Xploder cables and kit. For some reason the quality is clearer, but it is very pixelated. I've tried Pro Evolution Soccer 6 and Shadow of the Colossus (which has progressive scan, but doesn't seem to make much difference). Any ideas? |
