Home > Message Board > Video Games > Xbox > Videa and adio on xbox
Author Thread: Videa and adio on xbox
Username: Jsoon
Pasco, Washington
OK....i know there is probably a very simple solution to this but i don't know very much about audio/video connections. I just bought a Panasonic Home Theater system. I positioned my speakers, connected it to my tv with a Composite video cable. I also bought a new tv. its just a small 15" polaroid lcd tv, it has both composite and component video hookups. The problem im having is connecting my xbox to both my surround sound and tv. I know i can use the xbox's adio/video cables which plug directly into the reciever, but that is only giving me audio. How can i get the picture on my lcd. Its an original xbox by the way. thanks
Username: Jsoon
Pasco, Washington
oh and to clarify im not completely retarded, i know i can plug the xbox directly into tv but i want it connected with my surround sound also.
Username: Basshead86
FTW
Post Number: 9741
you plug the yellow plug from the Composite video cables(also called RCA cables) into the back of the Tv.
the red and white audio should go into the back of the HT system
Username: Jsoon
Pasco, Washington
oh yea i already got it about 15 minutes after the post, thanks tho. The problem i had was that the video on the composite cable didnt reach, so i ended up buying S video and component cables with an rf modulator. looks and sounds great
FTW
Post Number: 9751
good to hear, now play that thing!:-)
Post:
Username: Need to Register?
Password: Forgot Password?
Action: Upload Upload Image
Home > Message Board > Video Games > Xbox > Videa and adio on xbox [ « Previous ] [ Next » ]
