Home > Message Board > Video Games > Playstation Portable PSP > PSP2 problems!!!
Author Thread: PSP2 problems!!!
Username: Carrieakasha
Hey there!
My PSP 2 worked fine till yesterday when all of a sudden it couldn't read the UMD disc anymore. I turned it off and back on but on the start menu, the UMD logo didn't display, just like if there was no disc.
Can anyone help!!!
Relevant Product Info
Username: Camaro823
British Colu...
Post Number: 812
Busted !
And? That's it? isn't there a way to fix it? i didn't have time to take it to the Sony shop :-(
Username: Camaro823
British Colu...
Post Number: 813
I wouldn't recommend opening the PSP yourself, you can cause more damage then you hoped for and plus if you realize once your into it, that you can't fix it, Sony will not fix it. You don't have to take it to a Sony shop, call Sony. I had a problem with my ps2 and they fixed it for free( less S&H) and my ps2 was 3 yrs old. So give them a call and state your problem, it won't take much time.
Username: Seanpenn
Post Number: 14
Hm... might be a bad UMD disk, try a different disk. I had a disk that stopped working before
http://forum.ecoustics.com/cgi-bin/bbs/show.pl?tpc=8880&post=895892#POST895892
JC >>>>
I'm not planning at all to open it myself :-) I'll give Sony a call and see what they can't do. I have no garantee papers unfortunately but i really hope they can fix it!
http://forum.ecoustics.com/cgi-bin/bbs/show.pl?tpc=8880&post=896229#POST896229
Hey Sean;
I tried other UMD's and they didn't work either! :-( So i'm quite sure the problem comes from the lense!
Username: Nikk
Post Number: 978
It is possible to fix it, but you need a lot of patience, hand hability and a good how to guide...I have fixed my PSP 1 or 2 times...
Username: Nikk
Post Number: 979
Obviously you will need to have the spare parts you will need, that's a difficult part...
Post:
Username: Need to Register?
Password: Forgot Password?
Action:
Home > Message Board > Video Games > Playstation Portable PSP > PSP2 problems!!! [ « Previous ] [ Next » ]
