Home > Message Board > Video Games > Playstation PS2 or PS3 > PS2 Slim spins sometimes, jerks somet...
Author Thread: PS2 Slim spins sometimes, jerks sometimes
Username: Helen4709
Okay, just bought a PS2 slim clear case for my son on Ebay. Hooked it up, and some of the games will do a jerky spin, and others will spin normally right away. He's in the process of checking all his games, and so far has more that don't work than work. DVDs aren't working either. It doesn't matter what color the back of the disc is. What can we do?
Relevant Product Info
Username: Project6
Post Number: 9414
Seems like you have a bad PS2. You may want to return it ASAP. Having to fix or rig your disk is totally unacceptable. This is not your fault nor is it the fault of your disks. If it does not work the way it was designed, return it as it is defective.
I hope it wasn't a used unit from somebody else's problem stock. Good luck.
Username: Camaro823
British Colu...
Post Number: 551
thats what i'm thinking, IMO yor playing with fire when buying consoles from ebay unless its stated as brand new.
Post:
Username: Need to Register?
Password: Forgot Password?
Action:
Home > Message Board > Video Games > Playstation PS2 or PS3 > PS2 Slim spins sometimes, jerks somet... [ « Previous ] [ Next » ]
