Thread: PS2 Progressive scan |
Bronze Member Username: Hawker152
Post Number: 15 Registered: Nov-05
| Posted on Sunday, July 23, 2006 - 10:03 pm: |
I have just gotten the component cables for the ps2. I have changed the output to Y P Br or whatever on the system configuration. While watching a dvd i push stop and go to the setup menu. I can not change the tv size or change it to progressive scan because it is grayed out and wont let me turn it on or off. Im running it to at 56" JVC HDTV. Someone help. I have tried everything. Thanks. |
Relevant Product Info
Silver Member Username: Camaro823
British Colu...
Post Number: 493 Registered: Jun-05
| Posted on Sunday, July 23, 2006 - 10:37 pm: |
Try posting this in the home theatre section, a whole bunch of ppl can help you with this one |
New member Username: Jt7031
Toledo,
OH
United States
Post Number: 1 Registered: Aug-06
| Posted on Thursday, August 17, 2006 - 04:52 pm: |
need help turning ps2 dvd pro scan off , when trying to play dvd screen is blank and wont allow view of dvd menu, do not have a pro scan tv made a mistake by turning pro scan on can anybody help???? |
British Colu...
Post Number: 596 Registered: Jun-05
| Posted on Thursday, August 17, 2006 - 07:24 pm: |
How did you turn it on ? |
