Thread: Connecting an xbox to computer? |
Silver Member Username: Hondarider
Glidden,
Iowa
U.S.
Post Number: 193 Registered: Sep-05
| Posted on Monday, December 12, 2005 - 11:07 pm: |
Can connecting an xbox to a computer with an cat 5 cable do anything? Is it possible to get music from your computer to your xbox hard drive? |
Gold Member Username: Insearchofbass
Post Number: 3870 Registered: Jun-04
| Posted on Tuesday, December 13, 2005 - 02:03 am: |
I'll wait and see what others say but one way I know for sure would be to put the files from your hard drive onto a burnable cd after you change them from mp3 files if they are in that form which I would assume they are and convert them to wave files this would make them burnable to a burnable cd and be able to be played on the xbox cd rom just like a bought music cd would if you popped it in the xbox cd rom drive from there you could save your music on the xbox hard drive just like you would any bought music cd....to save your burnable discs you might be able to use a rewritable disc and just copy and delete as you get all the song over to the xbox hard drive that you wanted there...if that doesnt work youll just have to use the standard burnable discs |
Post Number: 3871 Registered: Jun-04
| Posted on Tuesday, December 13, 2005 - 02:06 am: |
now you got me curious I may try the rewritable idea myself and see what happens |
Glidden,
Iowa
U.S.
Post Number: 194 Registered: Sep-05
| Posted on Tuesday, December 13, 2005 - 11:53 pm: |
thanks for the info. But i dont have a CD burner i was thinking it might be possible to go straight from the computer hard drive to the xbox hard drive through a cat 5 cable? |
Bronze Member Username: Hammondrckr
Post Number: 13 Registered: May-05
| Posted on Wednesday, December 14, 2005 - 12:06 am: |
you would either need a crossover cable or a hub to pull that off, even the crossover might be pushing it ~alan |
Post Number: 3925 Registered: Jun-04
| Posted on Thursday, December 15, 2005 - 06:53 pm: |
you cant access the xbox hard drive with your computer as far as I know ...get a cd burner drive off of www.ebay.com or www.pricewatch.com or you could buy a dvd burner drive and be able to burn cd's and dvd movies in one unit their fairly cheap and are easy to install yourself if you have a open 5.25 bay otherwise you will will either need a external drive or mod the wires to run ontop of the pc case and mount the internal drive on top of the case....where theres a will theres a way |
Post Number: 3926 Registered: Jun-04
| Posted on Thursday, December 15, 2005 - 06:59 pm: |
you sould be able to do this for 30 to 40 dollars |
Post Number: 3930 Registered: Jun-04
| Posted on Friday, December 16, 2005 - 03:06 pm: |
if you buy a dvd burner get dvd shrink and dvddecrypter and youll be able to copy any dvd you own .....use decryter first to remove encrytion then use dvd shrink to fit that file onto your dvd burner disk....do it in this order and youll never have any problems with the disk not playing when you pop them in a ps2 or xbox or regular dvd player |
Glidden,
Iowa
U.S.
Post Number: 196 Registered: Sep-05
| Posted on Wednesday, December 28, 2005 - 08:24 pm: |
Do you have to buy a dvd shrink and a dvd decrypter seperately or do some dvd burners have it? |
Post Number: 4211 Registered: Jun-04
| Posted on Wednesday, January 11, 2006 - 04:48 am: |
you have to download both of them off the web....they are free and are installed after your factory software that came with the burner drive is installed .....usually the stock software is nero burning software |
Post Number: 4212 Registered: Jun-04
| Posted on Wednesday, January 11, 2006 - 04:50 am: |
stock meaning what comes with the drive....you then download dvd shrink and dvd decryptor and install each of them on your computer as well |
New member Username: Copperhead_c
Post Number: 1 Registered: Apr-06
| Posted on Sunday, April 16, 2006 - 05:39 am: |
i have an hp media center m7334n with rca AV in puts on it. i was wandering if i could possibly play xbox on it with the standard video cables |
Silver Member Username: Lewass
Boomfield Hills,
MI
Post Number: 664 Registered: Jan-06
| Posted on Monday, April 24, 2006 - 03:33 pm: |
honda rider, the answer is YES you can connect to your computer over the network. You need to buy Action Replay and then you can download the software to load onto your xbox harddrive, that will allow your xbox to be seen on your network, just like any other computer. From there you can transfer files through the ip address of your xbox. (go to your router page and locate all attached devices, then you will see what the ip address is, from there, open your web browser and type in http://insert.xbox.ipaddress.here) Also, a crossover cable is nothing but a way to skip using a hub or switch when connecting two devices, and it has nothing to do with connecting your xbox to your computer. (unless you didn't have a home router) CCL, the answer to your question is also YES. Not only can you play xbox through it but you will also be able to take advantage of your media center features, such as being able to take screen shots, and even record your gameplay! I wish I had a computer like that... I'd record myself whoopin all your a.sses in halo 2! |
Post Number: 2 Registered: Apr-06
| Posted on Wednesday, April 26, 2006 - 02:58 pm: |
but how do you do it |
Bronze Member Username: Tiggerboi87
Pensacola,
FL
United States
Post Number: 23 Registered: Jun-06
| Posted on Thursday, June 15, 2006 - 08:51 pm: |
couldnt u just connect the two with an ethernet cable |
Bronze Member Username: Exman494
Las vegas,
Nv
Usa
Post Number: 75 Registered: May-06
| Posted on Wednesday, June 21, 2006 - 11:06 pm: |
you can connect to your xbox by downloading flashfxp...just put in ur ip.. username and password are both xbox.. but u need linix...i got dat..hehe and splinter cell or mech assault Joe |
New member Username: Halo_2
Post Number: 10 Registered: Jun-06
| Posted on Thursday, June 22, 2006 - 05:33 pm: |
ALRIGHT WELL JOE IS RIGHT YOU WILL NEED A SOFTMODDED XBOX WHICH IS EASY TO GET AND YOU HAVE TO BE SITTING IN THE DASHBOARD IF I AM RIGHT YOU CAN MOD HALO 2 THIS WAY BUT IM NOT SURE CAN ANYONE ANSWER BACK PLEASE |
Las vegas,
Nv
Usa
Post Number: 82 Registered: May-06
| Posted on Thursday, June 22, 2006 - 06:19 pm: |
yeah u can mod halo2...but when connectiong put in splintercell..go to start game....linix..and then it will give u alist...i think u click..settings...(sry havent done this in a while)..and then..click on somthin else...if some1 wanted me to walk them threw it i can.. Joe |
New member Username: Corey1
Adelaide,
S.A.
Australia
Post Number: 1 Registered: Sep-06
| Posted on Friday, September 01, 2006 - 05:50 am: |
How can i put emulators onto my xbox from my pc, it has been modded. i dont know much about my xbox or the computer. some onfo on my xbox are "Bios (256)evoX m7 ejectfix. kernel 1.00.5105.01 EvolutionX V+3935" hope someone can help. if you can please e-mail me at Corey_Kovac@hotmail.com |
New member Username: Madsickpenguin
Post Number: 1 Registered: Aug-07
| Posted on Monday, August 06, 2007 - 11:11 pm: |
Hi, I have the same computer as ccl does (above) and connected my xbox to comp with RCA cables; what program do I use to play xbox through? I can't seem to figure it out with media center/player. Thanks! |
Post Number: 2 Registered: Aug-07
| Posted on Wednesday, August 08, 2007 - 11:34 am: |
Any thoughts? |
