Home > Message Board > Video Games > Xbox > Archive through February 02, 2006 > Xbox freezes during dvd
Author Thread: Xbox freezes during dvd
Username: Hardcorehehaw
I have a xbox with the samsung drive. During certain dvd's it will randomly freeze, sometimes for a second sometimes longer and then continue.
I'm using burned dvd-r's and the quality of the disc i just watched was like 80-90 percent.
The disc was also brand new, no scratches or finger prints.
Should i buy one of those dvd cleaning kits or is this just something i have to live with since i'm burning dvds?
Also when i play cartoons like Family guy or Futurama it looks all jittery whenever there is fast movement on the screen, like it's lagging. Usually on those the quality is around 50-60 percent. Is that normal?
Username: Reinhart
Post Number: 271
"I'm using burned dvd-r's and the quality of the disc i just watched was like 80-90 percent.
Should i buy one of those dvd cleaning kits or is this just something i have to live with since i'm burning dvds?"
Does this problem manifest itself with original press-replicated DVDs?
Plus, try different recordable discs and use the one that works best. You may also wish to write your discs at slower speeds.
"Also when i play cartoons like Family guy or Futurama it looks all jittery whenever there is fast movement on the screen, like it's lagging. Usually on those the quality is around 50-60 percent. Is that normal?"
A lot of compression will cause various kinds of artifacting such as macroblocking. It may be possible that you are trying to copy an entire RSDL (dual layer) disc over to a single layer recordable DVD. To put that much data into such a disc, you'd need to use a lot of compression.
I'd say that you are copying the DVDs in question using heavier than normal compression, which will cause some quality issues like you've described. - Reinhart
Home > Message Board > Video Games > Xbox > Archive through February 02, 2006 > Xbox freezes during dvd [ « Previous ] [ Next » ]
