Home > Message Board > Video Games > Xbox > Archive through February 02, 2006 > Anyone has problems with an xbox 360
Author Thread: Anyone has problems with an xbox 360
Username: Islandboy808
Mililani, Hawaii
US
Post Number: 203
i just got mine about a week ago and yesterday while i was playing on line it suddenly froze on me.so i figured i restart the system,the when it restarted the controls didnt work.both of my controls were blinking,so i then turned off my power and turned it back on and still the same.i had to literally pull the power plug from the back of the system,put it back in,and then it worked.did anyone else have this problem and what do u guys think i should do.maybe return it,remember it works now.
Username: Chaunb3400
Huntsville, Alabama
U.S.
Post Number: 2804
i havent had any problems, beside some of my os xbox games dont work, and are there any left from where u got it, if so return that b!tch
Username: Reinhart
Post Number: 255
It might have been a random glitch that required an unplugging to clear it.
As for backwards compatibility, only some X-Box games will work on the X-Box 360. Keep your X-Box to play X-Box games as opposed to relying on the 360 to play them. - Reinhart
Username: D_singh
Post Number: 58
More games should become backwards compatible with time. It's a goddamned inconvenience for the customer to have to d/l the software to read all the old games.
Home > Message Board > Video Games > Xbox > Archive through February 02, 2006 > Anyone has problems with an xbox 360 [ « Previous ] [ Next » ]
