Thread: What can xbox mods do for me? |
Silver Member Username: Hondarider
Glidden,
Iowa
U.S.
Post Number: 190 Registered: Sep-05
| Posted on Wednesday, November 23, 2005 - 05:25 pm: |
What can modding ur xbox allow you to do? Can you get something that lets you save games to the xbox? |
Gold Member Username: Chaunb3400
Huntsville,
Alabama
U.S.
Post Number: 1857 Registered: Jul-05
| Posted on Wednesday, November 23, 2005 - 05:51 pm: |
many things, a mod can be as simple as changing the case or adding a larger hard drive, it just depends on what u want For ex. I have a Xbox with a 250 gig hard drive so i can save whole games and play them when i want. |
Silver Member Username: Reinhart
Post Number: 203 Registered: Nov-05
| Posted on Saturday, November 26, 2005 - 12:28 am: |
A modified X-Box can allow you to do many things, including saving whole games to the hard disk and playing them from there. It will even allow you to play arcade and vintage games from older systems through emulation. - Reinhart |
Glidden,
Iowa
U.S.
Post Number: 191 Registered: Sep-05
| Posted on Sunday, November 27, 2005 - 08:33 pm: |
How much do those bigger hard drives cost? And is that all i would need to buy or do you have to have other mods for it to work? O and can someone give me a link to a bigger hard drive. |
Post Number: 217 Registered: Nov-05
| Posted on Wednesday, November 30, 2005 - 01:26 am: |
It depends. Check online, like bestbuy.com. But, you must prepare the hard disk for use in the X-Box, such as loading the necessary software components for the X-Box to run with it. In addition, the console itself has to have a modchip installed. - Reinhart |
Huntsville,
Alabama
U.S.
Post Number: 2383 Registered: Jul-05
| Posted on Wednesday, November 30, 2005 - 09:24 pm: |
im sure if u check google u could find somebody to do it for cheap |
