Thread: Xbox controllers compatible with xbox 360? |
Silver Member Username: Dustin3
Tigard,
Or
U.S.
Post Number: 102 Registered: Oct-05
| Posted on Sunday, November 20, 2005 - 11:17 pm: |
can you use the old controllers for the new xbox 360? |
Gold Member Username: Chaunb3400
Huntsville,
Alabama
U.S.
Post Number: 2152 Registered: Jul-05
| Posted on Sunday, November 27, 2005 - 02:19 am: |
havent tried |
Bronze Member Username: Jbecvar
Post Number: 74 Registered: Mar-05
| Posted on Tuesday, November 29, 2005 - 01:27 am: |
they aren't. the 360 wired controllers use usb plugs, unless they release an adapter, you're outta luck
Gold Member Username: Insearchofbass
Post Number: 3793 Registered: Jun-04
| Posted on Saturday, December 03, 2005 - 07:19 pm: |
just a guess here but it might be easier to consruct a wireless setup using the original xbox controllers |
Post Number: 3794 Registered: Jun-04
| Posted on Saturday, December 03, 2005 - 07:27 pm: |
My gosh they hacked the xbox 360 already. They hooked a usb 2.0 harddrive into it. Check it out. http://forums.xbox-scene.com/lofiversion/index.php/t464588.html |
Post Number: 3795 Registered: Jun-04
| Posted on Saturday, December 03, 2005 - 07:32 pm: |
more on the hardrive mod http://www.llamma.com/xbox360/
Post Number: 3796 Registered: Jun-04
| Posted on Saturday, December 03, 2005 - 07:41 pm: |
on the controller question to make a xbox 1 contoller compatable with 360....here you go... http://www.fury-tech.com/Modding/Xbox-Controller-PC-Conversion-Mod or http://www.ocmodshop.com/default.aspx?a=223 |
Huntsville,
Alabama
U.S.
Post Number: 2611 Registered: Jul-05
| Posted on Sunday, December 04, 2005 - 01:40 am: |
Thats sweet |
Silver Member Username: Islandboy808
Mililani,
Hawaii
US
Post Number: 202 Registered: Nov-05
| Posted on Monday, December 05, 2005 - 09:29 pm: |
i think they sell an adapter for it to work. |
