Thread: Trying to hook up my PS 2's ethernet through my network card on computer. |
| Posted on Saturday, October 22, 2005 - 03:32 am: |
I have a d-link wi-fi card, that gives me an internet connection. But i'm trying to connect my PS 2 to the wireless connection through my network card. Anyone know if it's possible, and if it is, how to do it? Thanks Yoshi |
Silver Member Username: Chaunb3400
Huntsville,
Alabama
U.S.
Post Number: 562 Registered: Jul-05
| Posted on Saturday, October 22, 2005 - 04:13 am: |
U would have to be the wireless adapter for the ps2 |
| Posted on Saturday, October 22, 2005 - 11:49 am: |
so theres no way to send your internet connection through your network card to your PS 2? wifi card-->computer-->network card-->PS 2 net connection is coming through the wifi card Perhaps with a router? |
Huntsville,
Alabama
U.S.
Post Number: 564 Registered: Jul-05
| Posted on Saturday, October 22, 2005 - 02:15 pm: |
A router would work 2 you can either run an ethernet cable from one of the four places in the back of the router or you can buy a wireless media station from linksys which makes it so your ps2 can be in anyroom that is not near your router |
| Posted on Friday, October 28, 2005 - 02:28 pm: |
yes you can, i currently have a cross over ethernet cable going from my ps2 to the pc's nic card. after that you just bridge the lan connection + wireless connect enabling you to go online w/ both -Stuey |
Unregistered guest |
| Posted on Saturday, December 10, 2005 - 04:58 pm: |
i have problem too i bought a ps2 network adpter to find my modem dosent direct hook up so i pluged cable in to back of my computer and set up settings and i cant find a connectiopn when testing |
