Home > Message Board > Video Games > Playstation PS2 or PS3 > MY PS2 IS NOT BOOTING THE GAMES? > Archive through March 16, 2005
Author Thread: Archive through March 16, 2005
Username: Kolomau
Daly city, Ca
U.s.a.
hello,
can someone help and tell me wassup with my ps2 or where can i go and fix it...well the thing about my ps2 is, its not booting up, the game or disc starts spinning and then it sounds like its getting stuck or its not booting or going through all the way? (it starts ticking, after the game or disk spins?)
please help
Relevant Product Info
Username: Project6
Post Number: 443
sounds like the disk is not catching on the spinners, disks are too thin. Some people put scotch tape next to the holes so that the spinners can catch it.
Username: Kolomau
Daly city, Ca
U.s.a.
can you please give me more info on how about i can do that? do i just put scotch tape around the whole hole? or little peices?
AND THANK YOU VERY MUCH FOR HELPING ME...
Username: Project6
Post Number: 447
yes, just around the whole. use a cutter to trim the edges so that there are no excess around the hole. All you need is to ensure that the spinner an grab the disk. It is very common on discs that are blue.
cheers
blank
souds like your disck is not clean try cleaning
Matt Whitesides
also if the disk is dirty the ps2 will keep trying to read the disk and can make noises like that if it cand find the first code track thing because it is sctrached ore something
Matt Whitesides
also with the blue disk thing they spin a lot faster than the non-blue disks so the give the system a harder time so they have more of a chance of doing something like that
Username: Project6
Post Number: 808
where did you get the information on blue disks spinning faster?
my ps2 spins the disk for 3 second the it stops and my lense duse not move how can i fix it
Username: Jrest
St. Louis, Missouri
Post Number: 14
I speak from experience. MY PS2 is 3 years old and I had the same problem with inserting a disc and hearing the system just click and hear the cd spin up and then click and hear it speed up again. A student of mine told me that it's actually a lens problem which SONY is aware of. So I called them, and they were very nice and sent me an authorized return number. Within 9 days, I had my PS2 back and it works and they didn't charge me at all.
Here's the link for the phone number to call.
http://www.us.playstation.com/support.aspx?id=howtoobtainservice
My PS2 is not reading disk,it tries to but doesn't for some reason and when I go to browser it sez disk read error.
Any suggestions of how to fix the problem?
alex king
when i press the main switch to turn my ps2 on the red light comes up and i press the restart button to start it up and it does not boot. please help
jerms
my problem started when i inserted a game, the console started to make noise... and i was alarmed to smell something inside the console. Immediately I turned off the console and for some few minutes turned it on...But all it shows is the start up screen and the games does not boot. Is this a problem with the lens? Is the lens destroyed?
hhhhhj
i can't load my ps2 game from the browser. Anyone know whats the problem.
DA XPERT
WHAT VERSION IS YOUR PS2
kase knochenhauer
where can I return my play station with out paying for shipping and handling
my play station will not read any game exept gran turismo 3 aspek any one know why and waht I can do to make it read other games
Absolute
my ps2 can only play games formated in dvd-rom i own a few games in compact disc format i beleave are the blue disc so i tried the tape trick but still no joy i dont get that noise or increase in speed just a disc read error and dvd-roms even do they work take an extream amount of time to load does this sound like a laser problem or simply time to by the slim ps2.....lol
nick the quick
My ps2 starts up fine but will not load the disc, all i hear is this clicking sound and a few beeps. It doesnt load many games made by EA Games. all of the other games made by other companies are fine.
A MORON LIKE U
I OWN A GAME CALLED SIMS A BLUE DISK. IT SEEMS ALL BLUE DISK HAVE AN EXPIRE DATE UR SOMETHING CUZ AFTER A FEW TRYS IT WONT WORK ANYMORE
to all the above get an xbox:`)
sorted:¬)
batmanforever1
i am having problems with my PS2 reading purple disks but NOT the silver (not copys) all the disks are original and it have not been chipped can any1 help? is it the laser? or the brain? or just sony screwing us all out of our money and having a good laugh at our expence?
i guess a lot of people have the same problem, my ps2 wont play the purple bottom disks. someone help me please!!!!!!
and no i am not getting an xbox
nobody
Buy a ps1
I have a game called wwf smack down!here comes the pain. And it won`t work on my ps2.HELP!
This is for A MORON LIKE U.DO NOT BY AN XBOX!That justs wasts money.And i know this is late but i just found this web.If you have a generator on your ps2 take it off-for the sims busting out.If your talkng about the regular sims keep it on.
Everyone On this link, Everyone call sony they will get your PS2 fixed for free all you have to do is pay shipping and handling, They know that there is a problem with it, so they will repair for free unless you have Physical damage you put on it, Good Luck,O yea also if you get the new "Thin" version of PS2 all it is basiclly is this problem fixed and the modem inserted in the system, So yeah they know the problem!
xboxmike
my ps2 wont read blu or playstation discs and its not the discs cause there new but it will read normal dvd disks on ps1 and and blue it just make a high spinning sound
xboxmike
my ps2 wont read blu or playstation 1 discs but it will read normal dvd disks but ps1 and and blue it just make a high spinning sound
Griffin4Us
Brand new thin PS2 (70000 series)NOT reading the silver discs. Plays the black PS games and the blue PS2 games just fine. Anyone got a clue about fixing this??? Please help.
Hey I got my Ps2 the first year it came out and now all I get when i try to play it is Disc Read Error. I tried cleaning the discs, opening it and cleaning out the dust but now nothing works. Please Help
pancho
adjusting the lens works i had the same problem and that did trick now it reads any game get info on how to adjust the lens before doing it
Hey my PS2 isnt reading any discs. I've tried everything. It makes a buzzing noise when you first turn it on. it goes to the main PS2 screen. I went to the browser and sat there for about a half an hour and at the bottom it just kept flashig Reading Disc.
I just fixed a PS2 for a friend last night. I couldn't believe it worked. He was getting "disk read errors" whenever he tried playing a DVD movie or a PS2 game that was on a DVD. His PS2 still read music cd's and games that are manufactured on cd's, so I knew that the laser still worked. I was knew to PS2 troubleshooting, and I found this guide, and it worked. No more problems.
http://arstechnica.com/articles/paedia/hardware/ps2.ars
I hope it works for you guys. Let me know. It is fairly simple to do.
FB
Why does my ps2 play some games but says disk read error on others.
Hi I Was wondering if i could possobly fix scratched ps2 games with a game doctor, or if that is a no no.
e-mail me.
sLiM_ShAdY
I bought a ps2 the year it came and and now it doesnt read any discs new or old. I have used a game dr. that cleans discs on the old ones and they still dont work. I have also taken it apart a few times and followed the guide on the link posted above. I really need help since the new slimmer ps2 is out of stock everywhere.
Delition
To Biggworm, thanks for the site. That was the one I was looking for when I stumbled upon this site. I just couldn't find the freakin' gear when I opened my PS2. Thanks again.
*~Mandi~*
San Andreas will not work even tho there arent any scratches and its clean... its the same for ESPN 2K5 Football but any other games work fine what do i do?? my PS2 is like 3 yrs old i think its time for a new 1.
my Ps2 will not read any disk. i click into browes and it says Disk Error
Fo Sho
yo fo sho my ps2 is a scph - 50002 and ive ajusted it so it reads a dvd a silver ps2 game a ps1 and a blue ps2 disk but it only plays ps1games and da blue ps2 diks fo sho how da hell do i fix dis
criff19
ok, i tried the laser adjustment....still no go....it seems that i get the browser screen when i click on it, then the screen goes blank, and thats it. When i adjust the laser, all it does is make it so i get the disk error prompt. so its either the error or no error but a blank screen. What the heck?? any ideas?
Username: Partyxxx
Neath, U K
WALES
What I tent to find is if you buy the game or thegaming station it tends to srew you around example i bought the original ps2 the day it hit the shops and it worked fine for like 4 hours i had a ps2 slimline version this x mas and i hought it would be cool to buy the ps2 gta series gta 3 gta vice city and gta san andreas bought gta 3 on a market stall for id already compleated it and solt it so it was just for muking around vice city brand new 1 gues what happent yep it read for 1 hour and then it crashed never to be played again san andreas must have been in the third batch couse that works fine...ps i got an x box there crap dont waste money !!! p.s.s couler of disk has nothing to do with it it's just the format that theyer made in likewise on a pc donlode music in mp3 format and most disk players wont read them so like wise with the disk and ps2 if this does help please e mail me to tell me the further problems ok ?
T_RIP
My MADDEN 2005 and other EA games wont load. But most of my other will like Socom II. What should I do.
my nbalive 05 is scratch because my ps2 drop with it and it kepts freezing when i play my season
how can i fix it,please help
T-Rip
I got mine to work just by cleaning the lense. You can look at this site http://www.h27.000k2.com/misc/ps2fix.htm it should show you how to clean it. My madden and all other game work now.
my ps2 would'nt load up games, it would say disk read error so I saw a guide on cleaning the lens, it worked fine then- for a week! Now it wont work again but does'nt say error. It just says reading disk. Any suggestions? Its about 4 years old.
Sergio
I have a problem i havent seen or heard of. When i try to turn on my PS2 it will turn off like 3 seconds after i press the power button. Very very seldom does it work without turning off but it really gets on my nerves cuz it rarely works.
Username: Araknid
Post Number: 171
you all can suck a nut becuz the color of the CD means absolute Sh1t and yes Xbox does blow.
Only some of my ps2 games work. When i go to browser it says reading disk... then it disappears and i hear a click click clikc and then nothing happens. PLEASE HELP ME because some of my very best games won't work on my ps2. PLEASE AND THANK YOU,
kyle
T-RIP20
Kyle thats the problem i had and then I cleaned the lense. It shows you how to do it on this website http://www.h27.000k2.com/misc/ps2fix.htm. You should only do that if you want to open up ur ps2. Tell me if that helps.
Username: Solid_snake
my ps2 does not play any adult dvds i insert in. it doesnt even read it. I need to get my groove on so someone please tell me what to do with my erection when it doesn't want to load the adult movie.
Username: Don_singh
Most of my ps2 games work expect san andreas but before i load up any game my ps2 makes chattering noise but when i bang it the game will load up but on san andreas it get to where the pictures come up when it is loading.
please help
Username: Don_singh
Can I buy anything to remove the scratches or cover them
would a disk cleaner work?
Username: Don_singh
two or three years, but all my other games work
Tevion.DeJohnson
I put in gta san andreas in my game system it won't read the disk please HELP ME!!!!!!!!!!!!!
Hi i have a Ps2 and my ps2 dose not spin the disk it starts and then affter a second it stops. i do not even get a disk read error it says reading disk for a half second and then nothing how do i fix this problem if you know please e-mail me at hotreno12345@comcast.net or put it here thank you.
mad elf
i got gta san andres a few days ago and it played fine now it is say ing unable to read disc and i can hear the music skiping i tried a scratch repair kit still no luck please help
jon,bc,canada
i own a x-box, ps2, gamecube, and i have never once hand a problem with my nintendo or xbox but my ps2 has so many problems. i have own 3 ps2, don't buy one of those ps2 thin's i have gone through 3 of them, in 3, 1 month. PS2 Sucks don't buy anythin sony
Self
my ps2 will only play audio cds..but when i put in a video game or dvd rom it says disc read error..any suggestions?
Top of pagePrevious messageNext messageBottom of page <
