Thread: Wireless Controllers - What are your favorites? |
Bronze Member Username: Griffin_andrews
Post Number: 22 Registered: May-05
| Posted on Thursday, August 11, 2005 - 07:39 am: |
I wanted to buy a couple wireless remotes and was curious which ones you all use. Can you give me a few suggestions? I've heard that logitech are first rate. Thanks GA |
JustPostAlready Unregistered guest |
| Posted on Wednesday, December 07, 2005 - 06:42 pm: |
I had a logitech for a couple of months and then the buttons started to stick. I keep all my stuff in good shape so I will be suprised if something may have been spilled on it |
Gold Member Username: Chaunb3400
Huntsville,
Alabama
U.S.
Post Number: 2892 Registered: Jul-05
| Posted on Thursday, December 08, 2005 - 11:22 pm: |
i use madcatz on my ps2 and no problems, and i have used them for about 2 years |
Dark Dragon Unregistered guest |
| Posted on Wednesday, January 04, 2006 - 03:57 pm: |
i use madcatz also and no problems, only that sometimes my bateries explote! other than that works fine! |
