Thread: Backing up my ps2 games on to a dvd |
musicmad Unregistered guest |
| Posted on Tuesday, March 02, 2004 - 02:09 pm: |
hi i need to know if i copy a ps2 game on to a dvd will it play strieght away |
| Posted on Monday, March 15, 2004 - 01:08 pm: |
It'll play if your ps2 console is modified. One of the ways of modifying it is to use a modchip. |
Bronze Member Username: Squattingdog
Post Number: 13 Registered: Mar-04
| Posted on Thursday, April 01, 2004 - 06:39 pm: |
you can also find software that will burn the corruped sectors over which is what ps uses for its copyright protection. Not that I would suggest such a thing.. |
Post Number: 14 Registered: Mar-04
oh just to clear that up you also need a dvd burner but i figured that was a given. |
| Posted on Wednesday, June 23, 2004 - 01:59 am: |
west |
New member Username: Kyle___berg
Post Number: 10 Registered: Jun-04
| Posted on Saturday, June 26, 2004 - 09:47 pm: |
MOO
Seal socom Unregistered guest |
| Posted on Saturday, October 16, 2004 - 05:09 pm: |
if tou can make copies were do u find the soft ware I have been every where and cant find it?Can u help? |
| Posted on Wednesday, September 14, 2005 - 07:16 am: |
Hi i want to know the same thing a long time ago and now am a expect at ps2 back up playing. Get a swap magic disk there easy and safe to use no mod chips then you can play back ups and if you have a dvd rewiter use dvd-r disk NOT DVD+R you should have a program that comes with the dvd rewiter but if it comes with nero get clone cd you then can make back ups and play them with out breaking you ps2 i do this all the time and a good tip when you buy or rent out a game before playing back it up and just use the copy to keep the real game in good condision MOD CHIPS COST A LOT AND BREAKS PS2 FASTER SWAP MAGIC IS SAFE |
New member Username: Budu
Post Number: 1 Registered: Oct-05
| Posted on Wednesday, October 26, 2005 - 10:58 am: |
how can I get the swap magic? |
New member Username: Justineve9
Post Number: 1 Registered: Jan-06
| Posted on Thursday, January 05, 2006 - 11:11 pm: |
can i back up ps2 games with a dvd recorder |
