Thread: Ps2 wont work on new television |
New member Username: Grudge
Post Number: 1 Registered: Apr-05
| Posted on Saturday, April 23, 2005 - 07:49 pm: |
i just bought a sharp 32c540 and i cant get any of my systems to work especially the ps2. i have tried with a rf switch but not the actual av cables. i also tried a nes and snes, with the appropriate inputs, and none of them worked either. has anyone ever heard of a problem like this before. i called sharp and they wanted a tech to come look at it. any help on this is appreciated |
Gold Member Username: Chaunb3400
Huntsville,
Alabama
U.S.
Post Number: 2532 Registered: Jul-05
| Posted on Saturday, December 03, 2005 - 12:22 am: |
bump |
Bronze Member Username: D_singh
Post Number: 56 Registered: Sep-05
| Posted on Wednesday, December 07, 2005 - 11:48 pm: |
what is meant by this term "bump"? |
Huntsville,
Alabama
U.S.
Post Number: 2853 Registered: Jul-05
| Posted on Thursday, December 08, 2005 - 12:32 am: |
2 push a thread back to the top of the board so people will see it |
Silver Member Username: Reinhart
Post Number: 264 Registered: Nov-05
| Posted on Thursday, December 08, 2005 - 10:27 pm: |
Check the settings and connections on your television. For instance, if you have the AUDIO OUT hooked up on your TV to your receiver, this might cause the TV to cut off its own speakers as you would be listening to the audio from the receiver. Another possibility could be your TV's sound settings, like if the speakers were set OFF in the menu. - Reinhart |
