Home > Message Board > Video Games > Playstation PS2 or PS3 > Archive through March 31, 2006 > Problems w/ any game system
Author Thread: Problems w/ any game system
Username: Jakdaxtersgirl
Post Number: 375
If u have any problems w/ ur PS2, PS, XBOX, or any other game system please feel free 2 list ur problems here & I'll be able 2 help u. Thanks! :-)
Username: British_power
Post Number: 1109
no u cant only i can!
thewes
Hey,I just bought a slim ps2 at a garage sale.I found it by chance.But there is a parental password on it.I can't get it to play dvd's.Do you know how i can change the password?
Post Number: 419
does it have a thing called control 8 or something like that? Mayb u should ask the 1st owner 2 change the password
Username: Ealex
I bought The Seed of Chucky and I'm trying to watch it on my PS2,but my dad bought it from someone.And I played a movie that can get pass the parental lock, and i went to the setup menu then went to the parental controls and custom setup and pause mode are highlighted but parental control isn't and i can't ajust anything. can someone please help me?
Post Number: 459
? so your ps2 parental control thingy's not highlighted? You're saying 2 much! I'm getting confused, I have no idea...
Username: Ealex
yes i'm saying the parental thing isn't highlighted
ps2aquirer
My Ps2 skips whenever i play like it makes a clanking noise in it ..can you help me or tell me a way to help fix it!
dalen
my ps2 is dead it wont even play brand new games it just keeps loading
dalen
can you help
Username: Stars
Post Number: 33
Make sure it's plugged in right, & /or have it checked...
something might be wrong w/ the disc, it could b scratched...ummm probably clean it..
i press the power bttn on my ps2 (slim)-i get green light for 2 seconds then red light. i don't hear any noise from motor. there were no precursers to this problem. looking at disk with door open i see its hard to spin the disk.
Username: Stars
Post Number: 42
clean it, check the disc, have it checked..
When I pressd the open disc tray button and it takes longer than the average time for it to open and when it finally does open I put the game in and it starts to make a clicking sound it kind of sounds like a disc skipping in stereo. So I wait for the game to load but it dosen't so I go the Browser and it says it's reading the disc but it never gets around to actually reading the disc. HELP!!!
Username: Stars
Post Number: 49
maybe your disc is scratched, maybe you're playing it too much and it's old and getting worned out. Have it checked, buy a new one, just deal with it, or don't play your PS2, get a Gamecube or Xbox.
Ok thsi will be a hard one for anyone hopefully someone can gimme some help...Ok my brother threw my system on the floor and then it busted the front now the genius i am i opened the ps2 up played around with wires and everything started to look to be ok but when i start my ps2 the game spins like a 180 degree turn and it stops and nuthing is read can someone help
Username: Stars
Post Number: 168
well, probably next time u shouldn't mess w/ the wires if u do't kno what 2 do, but I bet it's broken or something because it dropped, so i suggest u should buy a new one or have it checked, oh and keep your ps2 away from your little bro next time. :-)
mine is totaly stuck. the light wont comeon at all and its drivin me crazy
Username: Chaunb3400
Huntsville, Alabama
U.S.
Post Number: 634
search google and maybe u could find a guide
Gareth Bradbury
I recently got a brand new game for XBOX. But when i turn the XBOX on it makes a constant clicking noise and comes up with the XBOX Logo and then freezes. Can you please help me!!!
When i'm playing my ps2 like madden 06 when the game starts to load to play the game it make a clicking noise i have to wait like 5mins before it stops or longer... that clicking noise freezes the game while i'm playing the game ... what should i do...send help to Rdg1x@yahoo.com or just reply on this site...
wright
when i play mlb 2006 (brand new got it for x-mas)for more than an hour on my ps2 it freezes i play it for an hour and it just freezes up (this happens almost every time i play it) can someone please tell me how to fix it
Username: Etech
Hi all, I have a slim model ps2, all the functions work , but the system Freezes after about a minute of use can anyone help me please?
Thanks.
Home > Message Board > Video Games > Playstation PS2 or PS3 > Archive through March 31, 2006 > Problems w/ any game system [ « Previous ] [ Next » ]
