Home > Message Board > Video Games > Xbox > Archive through February 02, 2006 > Xbox & optical cable?? Help
Author Thread: Xbox & optical cable?? Help
Hello.
I know that I should turn on the optical output on the dashboard. But I can't find the place where I should do it.
Can anyone help me?
I have installed a SmartXX chip, and I am using Evox and XBMC.
Kind regards
Anders
Optical question
I got the same question...I have the optical audio hooked up, but it only gives me the option to turn on the dolby and the DTS. It says nothing about the optical...how do you turn it on????
Username: British_power
Post Number: 1049
um to anonymous y did u put that down if u were going to put anders its like me putting anonymous then putting thanks British Power..and can u tell me wut this is
Post Number: 1050
o o
--- see wut i mean
Home > Message Board > Video Games > Xbox > Archive through February 02, 2006 > Xbox & optical cable?? Help [ « Previous ] [ Next » ]
