Thread: Backing up ps2 games |
| Posted on Wednesday, November 24, 2004 - 07:27 pm: |
i am a newbe at this i need help with useing alcohol120% i need to now what i need to play the backups on my ps2 and how about doing it |
New member Username: Ninja778
Post Number: 3 Registered: Apr-05
| Posted on Friday, April 22, 2005 - 03:07 am: |
me too! is alcohol 120% the only prog that does backups? is there a specific kind of dvd and are dvd's the only kind of disc u need to back up games... i'm asking because i know that not all games on ps2 are on dvd... |
| Posted on Saturday, June 25, 2005 - 08:02 pm: |
you guys can use dvd decrypter its awesome. its free as well!! you can do alot of different things with it... goodluck |
Bronze Member Username: Dodgedifferent2
Sarnia,
Ontario
Post Number: 44 Registered: May-05
| Posted on Monday, June 27, 2005 - 07:22 pm: |
i tried dvd decrypter and it did not work, maybe it was the discs i used. What are you using? |
Shelton of PENandPIXELS.com Unregistered guest |
| Posted on Wednesday, August 17, 2005 - 09:39 pm: |
- Open the image in ISO buster and copy the files to a folder - Patch the relevant files with DVD Scanlite 3.5 - New project in Nero: UDF/ISO DVD (The last option) - Drag files into Nero in the order they appear in ISO buster - Burn |
Silver Member Username: Rovin
Trinidad & T...
Post Number: 421 Registered: Jul-05
| Posted on Saturday, September 10, 2005 - 12:09 pm: |
Of course your machine MUST be MODDED to play backups . There are very few brands of dvd-r blanks that work , RIDATA & PRINCO works best ,also seen ppl use HP rewritables & it runs well too . Nero ultra 6 is what is used - But note ,its a secret ,there is only 1 brand of dvd burner that the experts like me use that does Ps2 dvd game perfectly & i don't wanna reveal that right now ,if anybody on knows then feel free to say it ... heh heh . |
New member Username: Justineve9
Post Number: 2 Registered: Jan-06
| Posted on Thursday, January 05, 2006 - 11:13 pm: |
can i back up ps2 games with a dvd recorder |
Silver Member Username: 420pimp2
Post Number: 127 Registered: Jan-06
| Posted on Thursday, January 12, 2006 - 04:06 pm: |
Rovin it's a Multiformat dual layer dvd writer 16x i have one. |
Post Number: 128 Registered: Jan-06
| Posted on Thursday, January 12, 2006 - 04:12 pm: |
i also have nero 6. What do you do just go to copy discs rovin?
