Thread: 512 mb ram |
New member Username: Marlakh21
Cowden,
IL
United States
Post Number: 1 Registered: Jul-09
| Posted on Thursday, July 23, 2009 - 08:24 pm: |
ok this is the deal i am suppose to be running 512 mb ram and ma oly running 368 mb, i use to run at 512 but some thing happend. i can no longer use my printer is there any way to cahnge the settings back to default with out using the recovery disk? |
New member Username: Spin
Post Number: 7 Registered: Jul-09
| Posted on Friday, July 24, 2009 - 08:43 pm: |
do you have on board video? Your pc could be sharing your ram with on board video. There are settings in your bios to change it. Maybe if that is what is going on you can change the amount of ram used for video in your bios settings. Usually you hit a key while booting to enter the bios. Then look for the on board video settings and lower the amount of ram it can use. |
Bronze Member Username: Pjmaster
United Kingdom
Post Number: 14 Registered: Aug-09
| Posted on Thursday, August 06, 2009 - 05:07 am: |
There might be some problem within your system. Some spyware tends to use a lot of memory from the pc. I recommend you go for a anti-spyware to sort out the problem. |
New member Username: Peter_benders
Sandiego,
CA
US
Post Number: 1 Registered: Jun-09
| Posted on Thursday, August 13, 2009 - 09:24 pm: |
ok the problem may be in the ram itself. check for any problems if not the problem may be one of the above ones |
Cowden,
IL
United States
Post Number: 2 Registered: Jul-09
| Posted on Saturday, August 15, 2009 - 07:55 pm: |
none of the above is the problem every thing i try ends up telling me i have a virtual memory error. so i would say it is the ram itself. any suggestion on how to fix? |
Bronze Member Username: Kngsze
Post Number: 24 Registered: Mar-06
| Posted on Tuesday, August 25, 2009 - 10:20 am: |
You cannot fix faulty RAM. Download MEMTest 86 (its free) and run it to see if it show any errors (you need to brun to CD and boot from the CD). Your best option would be to get some new RAM and of course, upgrade while you are there. It's 2009 and your still running 512. Go to 1GB at least! |
New member Username: Marksmith
City,
State
United States
Post Number: 1 Registered: Sep-09
| Posted on Monday, September 14, 2009 - 08:20 am: |
There might be some problem...you can recover default setting using restore point...if in case you lost some of your data...you can use data recovry software from recoverybull software... Mark Smith http://www.recoverybull.com |
New member Username: Gurugulabkhatri
Post Number: 5 Registered: Sep-09
| Posted on Thursday, September 24, 2009 - 04:22 am: |
I am not able to understand your actual problem, explain in detail your problem |
Bronze Member Username: Gibslara
Post Number: 17 Registered: Nov-09
| Posted on Monday, November 23, 2009 - 05:15 am: |
Dear ,512 mb ram is not using in upcoming computer. This was a oldest technology to use 512mb ram in system. I think you should buy 1gb ram to make your system more attractive. |
