Thread: Got picture for my laptop to tv but no sound? |
New member Username: Pickles68
Post Number: 1 Registered: May-09
| Posted on Tuesday, May 26, 2009 - 01:52 pm: |
Hi I have connected my laptop to tv using a vga to vga cable.... (think thats what its called, lol)....anyways, got a great picture, sound coming from the laptop but not from the tv speakers....any help greatly appreciated........ Ta! Clare x |
Gold Member Username: Riconissan
Post Number: 1033 Registered: Feb-09
| Posted on Tuesday, May 26, 2009 - 04:26 pm: |
alice, You need an adapter like this. 3.5 mm to RCA. http://www.iwonatec.de/product_info.php?cPath=195_196&products_id=2462&awsid=cdc 56d6c17e47ba7300db0a8f3759966 |
Post Number: 2 Registered: May-09
| Posted on Tuesday, May 26, 2009 - 05:04 pm: |
so this goes into the laptop, but what is put in at the other end?? (sorry if i sound dduuuhhh but I ain't got much of a clue! lol x) Clare x |
New member Username: Numan2good
Post Number: 8 Registered: May-09
| Posted on Wednesday, May 27, 2009 - 01:14 pm: |
man which TV are you using.... i need some of the detail how have you done that... like which input you use on the TV side? or is there any other device so we can attach laptop to our TV i m using VIZIO lcd..... any reply would be highly appriciated.... |
Post Number: 3 Registered: May-09
| Posted on Wednesday, May 27, 2009 - 04:45 pm: |
its a LG tv scarlet. I am using the vga plug at the back.... this then attached to my laptop again through the VGA port. great pic, no sound.... |
Post Number: 9 Registered: May-09
| Posted on Thursday, May 28, 2009 - 01:51 pm: |
hello alice jones well i am having a vizio LCD and i have configured how i can attach my laptop to it/// i can help you out with your audio thing.. you just need a 3.5 mm audio cable with same male pins on both sides like we use with the usual headsets or ipod headsets.. then you just see where u have input the VGA cable in the TV set you should see the female jack there just plug one side there and other in the laptop..i hope this will work out with the audio problem of yours... did you got what i am trying to say? |
Bronze Member Username: Paulie0117
Cambridge,
Ontario
Post Number: 15 Registered: Dec-07
| Posted on Wednesday, November 04, 2009 - 11:28 am: |
Numan is correct be the way. You need additional (headphone to jacks) adapter installed into your (audio in) section at the back of your tube. Ya can make them yourself by splicing the end piece of an headphone or earpiece set to a pair of spare audio jacks....Good Luck.} |
