Home > Message Board > Computers > Networking > 108Mbps WIFI 802.11G/11b Wireless LAN...
Author Thread: 108Mbps WIFI 802.11G/11b Wireless LAN PCI Network Card, Online Shopping Deal
Username: Kingjerry
United States
Post Number: 11
Support high-speed wireless networking of up to 108Mbps, while providing seamless interoperability with all existing IEEE802.11g and IEEE802.11b wireless equipment
Better security, ideal wireless solution that offers an upgrade to a fast, new technology while protecting your past investments through interoperability with your current network equipment
Working range up to 200m indoor, 850m in open air
Standard PCI interface, compliant with PCI 2.1, 2.2, 2.3
Fully compliant with IEEE802.11g, IEEE802.11b 2.4GHz
Support 64/128/152 WEP encryption, WPA / WAP2, IEEE 802.1X, TKIP, AES encryption and security mechanism and 6 types of EAP
Support 802.11b/g transmission power manageable, QoS supported
Support 32bit PCI interface, 108/54/ 48/36/ 24/18/12/9/6/ 11/5.5/2/1 mbps data rate
Equipped with 180 degrees external antenna manual adjustable for best transmission
2 working modes: Infrastructure (AP needed) and Ad-Hoc (AP not needed)
Data filter from various wireless workstation capable
Provide window-based diagnostic tools, most notably, site survey, link quality test
Wireless seamless roaming supported, greater flexibility to locate or move networked pcs
Seamless connectivity to wired Ethernet and easy to install and user friendly, just plug and play
Transmit Power: 20dBm max, low power consumption and manageable
Frequency range: 2.4-2.4835GHz
Gain of external antenna: 3 dBi
LED indicator: Link/Act
Operation system: Windows95/98/Me/2000/NT/XP
Pictures are only for reference, take products for real object as standard! ( Appearance may be a little different, but function is the same as description )
All these will only cost you EUR 15.59. What a nice deal! If you're hesitating, just visit the following link and then decide.
http://www.monde-tech.com/product_info.php?products_id=13
Post:
Username: Need to Register?
Password: Forgot Password?
Action: Upload Upload Image
Home > Message Board > Computers > Networking > 108Mbps WIFI 802.11G/11b Wireless LAN... [ « Previous ] [ Next » ]
