Home > Message Board > Computers > Speakers > Laptop and home theatre ?
Author Thread: Laptop and home theatre ?
Username: Geekfollower_83
I want to connect laptop to set of speakers which will be distributed in room & Bathroom:-)
I request advice on following Questions
1)Is this at all possible with good sound quality ?
If yes,
2)Which RCA cable, Amplifier and Speakers are recommended ?
3)I wish to fix
2 speakers on either sides of laptop
ideally something like this ( the
white ones)
1 in bathroom
2 on ceiling ,Diagonal corners in a room
Could someone pls suggest speakers which i could use, should i go for Bose speakers ?
Ideally, speakers which have inbuilt woofers would be great.
4) Is it possible to turn ON only the speaker which i wish, from computer S/w or switches ?
5)Can the amplifiers be power driven with USB port of Laptop or do they need a separate connection for power supply ?
6)Does the amplifier has also a headphone socket, so tht i could switch off all speakers and only listen to headphone
Many thanks in advance for your time and help.
Please feel free to give any suggestion / advice which i may have left out.
Cheers,
geekfollower
http://www.orbaudio.com/index.asp?PageAction=VIEWPROD&ProdID=69http://www.orbaudio.com/index.asp?PageAction=VIEWPROD&ProdID=69
Post:
Username: Need to Register?
Password: Forgot Password?
Action: Upload Upload Image
Home > Message Board > Computers > Speakers > Laptop and home theatre ? [ « Previous ] [ Next » ]
