Thread: Runtime Error on Dell Inspiron 1520 |
Silver Member Username: Dishlover
Toronto,
Ontario
Canad
Post Number: 251 Registered: Jun-06
| Posted on Monday, November 03, 2008 - 08:11 pm: |
Hi, Can someone please help me with following prolem. Thanks I can not download windows updates and also can not run msn messenger. While open the hotmail I can not delete forward open or reply }}my message in inbox. When I start my computer I get following message. Can not check window updates also I get following message. "Microsoft Visual C++ Runtime Liberary Runtime Error ProgramC:/.... This application has requested the Runtime to terminate it in an unusual way. Please contact the application support team for more information." Kindly help me and suggest what should I do. Thanks |
Gold Member Username: Th3pwn3r
I compensate...
Post Number: 8882 Registered: Jul-06
| Posted on Wednesday, November 05, 2008 - 11:24 am: |
I'm guessing that's a registry issue. I'd probably just wipe my hard drive and reinstall a fresh copy of windows. |
Toronto,
Ontario
Canad
Post Number: 252 Registered: Jun-06
| Posted on Wednesday, November 05, 2008 - 02:26 pm: |
Thanks for your help. |
Toronto,
Ontario
Canad
Post Number: 253 Registered: Jun-06
| Posted on Wednesday, November 05, 2008 - 02:27 pm: |
By the way is there any other solution to this? |
I compensate...
Post Number: 8885 Registered: Jul-06
| Posted on Wednesday, November 05, 2008 - 08:17 pm: |
What's stopping you from downloading the updates? Did you try a manual download instead of the automatic update feature? I'd try updated starting back from SP1 and then going to 2 and 3. It sounds like a lot of things are conflicting or corrupt. You're welcome by the way. |
Toronto,
Ontario
Canad
Post Number: 254 Registered: Jun-06
| Posted on Wednesday, November 05, 2008 - 08:21 pm: |
Even manual updates are not done the window for updates appear and then disappear at the same time. I am not familiar with SP1. Is is possible to explain please. I know somthing is definitely wrong or corrupted. I appreciate your help. Regards. |
I compensate...
Post Number: 8886 Registered: Jul-06
| Posted on Wednesday, November 05, 2008 - 08:32 pm: |
How are you attempting to download these updates? It's important to try to diagnose the problem. This is also not the easiest thing to solve without the computer in front of me haha. |
Toronto,
Ontario
Canad
Post Number: 255 Registered: Jun-06
| Posted on Thursday, November 06, 2008 - 07:51 pm: |
Ok thanks |
