Home > Message Board > Computers > Desktops > IE issue,plz help!
Author Thread: IE issue,plz help!
Username: Chicky3884
Post Number: 207
I used a program called malware bytes to get rid of avxp08 and I cant open IE anymore. I click and the hourglass comes up but nothing else. Im thinking maybe it quarentined a file that I need but I dont know. I called microsoft and after 3 hours they decided it was a corrupt file and there is no way to fix it because I dont have the disc. Please help!!!! Mozilla sucks!
Username: Felt
Post Number: 36
even though you probally wont get no help from this site i had a simallar problem running millium edition dont know if this will work for you or not go to settings . control panel . add remove programs click on microsoft internet explorer a pop up window appears click repair internet explorer then ok follow instructions GOOD LUCK
Post:
Username: Need to Register?
Password: Forgot Password?
Action: Upload Upload Image
Home > Message Board > Computers > Desktops > IE issue,plz help! [ « Previous ] [ Next » ]
