Home > Message Board > Computers > Storage and Media > Help with usb external harddrive
Author Thread: Help with usb external harddrive
Username: Snacks
Quincy, Florida
Post Number: 106
i have a usb harddrive i believe its 40gb, im not sure if either my computer shut off while updating or if i unplugged it wrong but now it takes like 15 minutes to get the computer to recognize it and i have 2gb ram and it makes it lag so hard as soon as it does.
is there anyway i could wipe it or fix it somehow? thanks
Username: Cmanxx
I hope I'm doing this correctly. Anyway, I store most of my music on 2 external hard drives. A 500G and a 1000G. Recently I noticed that I am now unable to run my Ipod and the 1000G HD at the same time. Thus making it impossible to load my Ipod without transfering the music to drive c first. The indicator in itunes program freezes up. If I unplug the ipod then th HD will work fine. If I unplug the HD then the ipod will work fine.
I have since dumped and reloaded my computer op system (XP home) as I normally do about once a year, but that didn't solve the problem. Is one or the other causing too much of a "load" or something?? This never happened before. Any advice?? Tks//Chris M.
Post:
Username: Need to Register?
Password: Forgot Password?
Action: Upload Upload Image
Home > Message Board > Computers > Storage and Media > Help with usb external harddrive [ « Previous ] [ Next » ]
