Thread: What do you think? |
New member Username: Christ649
Toronto,
On
Post Number: 4 Registered: Feb-08
| Posted on Saturday, August 30, 2008 - 10:18 am: |
Intel® Core2 Quad CPU Q6600 @ 3.40GHz Sapphire ATI RADEON HD 4870 X2 2048MB GDDR5 Dual Dual-Link DVI HD Audio Shader Model 4.1 (800 X2) stream processor PCI-Express 2.0 Graphics Card 4.GB DDR 3 @ 1333 MHz ASUS-Maximus Extreme Asus Triton 79 Cooler Ultra Black Aluminus ATX Mid-Tower Case 4x Seagate Barracuda 7200.10 500GB Hard Drive 1x LG GBW-H20L Blu-Ray Disc Rewriter, Max. 16X LightScribe DVD-Rewirter SATA, Black Antec TPQ-1000 1000W ATX EPS12V 80mm Fan 80PLUS RoHS Power Supply Viewsonic N3235w 32in 1366x768 LCD HDTV w/HDMI Windows Vista Ultimate
Gold Member Username: Th3pwn3r
I compensate...
Post Number: 8649 Registered: Jul-06
| Posted on Monday, September 01, 2008 - 11:18 pm: |
"Ultra Black Aluminus ATX Mid-Tower Case " Everything looks good but that. Since you plan on running a 4870x2 you'll want a bigger case. Those cards are 11'' long. Also, what kind of DDR3 running @ 1333? Not all ram is created equal. Any reason for going with a Q6600? I'd get something higher up personally. What's the purpose of this setup? |
Bronze Member Username: 3dges
Compton
Post Number: 44 Registered: Feb-08
| Posted on Thursday, September 04, 2008 - 09:12 pm: |
Post a picture of all your stuff or your Desktop if it is already put together. |
Toronto,
On
Post Number: 5 Registered: Feb-08
| Posted on Tuesday, September 09, 2008 - 10:56 pm: |
Bronze Member Username: Gibslara
Post Number: 16 Registered: Nov-09
| Posted on Monday, November 23, 2009 - 05:13 am: |
Wow!, What a configuration. I like all the information which is mentioned by you about Intel® Core™2 Quad CPU Q6600 @ 3.40GHz . I think this is a good thing for keep keep knowledge about technology. |
