Thread: Prolonged vedio encoding timing |
New member Username: Tukai65
Post Number: 1 Registered: Aug-08
| Posted on Monday, August 18, 2008 - 02:36 am: |
When I write on CD for vedio file from nero 6 . The encoding timing is too long. my mother board is G845 and RAM is 512 MB . Quality is not same to my computer. my CD writer is ASUS 10X. Please Help Me. |
Platinum Member Username: Glasswolf
Wisteria,
Lane
Post Number: 12162 Registered: Dec-03
| Posted on Tuesday, August 19, 2008 - 01:13 am: |
old hardware and old software. not exactly a blazingly fast system, and you're using software that's 2 generations behind the curve. it's going to be slow. If you want fast encoding, buy a core2quad system, overclock it, get a good video card like an HD4870 or 280GTX, run XP x64 or Vista x64, and use 4 to 8GB of DDR2. Then use a RAID 0 or RAID 0+1 array for the video storage. Upgrade to Nero 7.5 or 8.x and try again. |
