Thread: Enable Hi-speed usb port help |
Gold Member Username: Somedonniedude
Illinois
United States
Post Number: 1618 Registered: May-07
| Posted on Friday, May 30, 2008 - 01:50 pm: |
My computer is a Compaq EVO/ 2.4ghz Pentium 4. I have a total of 4 usb ports on the back of my motherboard, 2 of which are Hi-speed. My computer Identifies the non hi-speed ports, but will not recognize the Hi-speed ports. I read something about on startup or in the BIOS control you can enable the Hi-speed ports, but I can't seem to find it. Can anyone help please??? |
Platinum Member Username: Glasswolf
Wisteria,
Lane
Post Number: 12134 Registered: Dec-03
| Posted on Monday, August 04, 2008 - 02:33 am: |
should be under advanced chipset options, under integrated peripherals or some such. find the USB ports, and make sure they are set to 1.1 and 2.0 mode. not just 1.1 |
Wisteria,
Lane
Post Number: 12135 Registered: Dec-03
^^^^ in the BIOS that is |
Bronze Member Username: 3dges
Compton
Post Number: 57 Registered: Feb-08
| Posted on Tuesday, September 09, 2008 - 05:05 pm: |
yep |
New member Username: Perumexican
Post Number: 1 Registered: Jul-09
| Posted on Thursday, July 23, 2009 - 11:46 pm: |
My BIOS didn't say anything about USB anywhere. I decided to try loading the default setup. That did the trick. I looked for this solution for a long time. I hope this helps someone. |
