Thread: Emachine T3104 Desktop PC windows wont start successfully |
New member Username: Aok2
Post Number: 1 Registered: May-08
| Posted on Sunday, May 11, 2008 - 04:31 pm: |
My cousin shut off my computer yesterday while the internet program was still running. Now I have this message: I continue to get this error message (as if it is in a loop, and can’t get out.) “Windows didn’t start successfully. A recent hardware or software change might have caused this. [nope] "If your computer stopped responding, restarted unexpectedly, or was automatically shut down to protect your files or folders, choose “Last Known Good Configuration” to revert to your most recent settings that worked. "If a previous startup attempt was interrupted due to a power failure, or a Power, or a Reset button being pressed, or if you aren’t sure what caused the problem, choose “Start Windows Normally.” [choices] Safe Mode Safe Mode with Networking Safe mode with Command Prompt Last Known Good Configuration Start Windows Normally Okay. Regardless which option I choose above, it loops, and returns to this page. I do not have a recovery disk for the computer. What should I do then? |
Bronze Member Username: Haydog_08
Hot Springs,
Arkansas
US
Post Number: 49 Registered: Oct-06
| Posted on Monday, May 12, 2008 - 08:38 pm: |
what kind of computer do u have? what opperating system? XP or vista?... |
New member Username: Knightime
| Posted on Wednesday, May 14, 2008 - 01:59 am: |
i have the same problem at this time with my emachine. differant model t3985 doing the same thing keeps happening having to pick from the start up options, then once windows xp starts it automatically restarts the whole process over and over again....... i can do a system recovery but dont want to lose my files in doing so. you can go to emachines website and download a recovery files if you have access to another computer. in my case i need to get my files as im sure you do as well. any suggestions on how to remove my files from the internal hard drive? help if anyone has done this..... |
