Thread: Laptop Problems help needed |
Silver Member Username: Kewinn89
G-Bay,
Alabama
Usa
Post Number: 217 Registered: Dec-06
| Posted on Monday, March 24, 2008 - 11:28 am: |
I have a Tohsiba Laptop i've had it for about 2 1/2 years when i turn it on it saids toshiba and then it said windows XP but it just shuts off after that, do i need to buy a new hardrive or what?? |
Platinum Member Username: Project6
Post Number: 15541 Registered: Dec-03
| Posted on Tuesday, March 25, 2008 - 08:56 pm: |
Do you know how to boot in safe mode? Is the battery still good? |
G-Bay,
Alabama
Usa
Post Number: 218 Registered: Dec-06
| Posted on Friday, March 28, 2008 - 07:43 pm: |
yes something is wrong wit the battery but my uncle got it to work for me |
Platinum Member Username: Wingmanalive
A pic is worth
1000 posts!!
Post Number: 15436 Registered: Jun-06
| Posted on Friday, March 28, 2008 - 08:49 pm: |
Will it work without the battery? Just plugged in to AC power? |
New member Username: Tradestead123
Post Number: 1 Registered: Mar-09
| Posted on Sunday, March 08, 2009 - 10:38 pm: |
i have use laptop for many years and i'd like to reach it very much , so in my opinion if your battery is all right,then the most possible is that there is some thins wrong with your hardrive, may be you should have a new hardrive |
Bronze Member Username: Peeps365
Post Number: 14 Registered: Feb-09
| Posted on Saturday, March 14, 2009 - 11:20 pm: |
kevin u need to wipe the hard drive clean and pu a new OS on it should take care of the job |
Post Number: 15 Registered: Feb-09
| Posted on Saturday, March 14, 2009 - 11:24 pm: |
can get instructions on this from microsoft .com they walk u through it |
New member Username: Pumpkinman
Ny
Post Number: 4 Registered: Dec-08
| Posted on Sunday, April 26, 2009 - 11:27 pm: |
go into your bios and see if its reading your harddrive.if not new one? if it is reading the harddrive youll probally need to reinstall os |
New member Username: Dimyself
Irvine,
CA
Post Number: 3 Registered: Oct-09
| Posted on Tuesday, October 06, 2009 - 05:21 pm: |
The other reason I've seen this is that your CPU heatsink fins are clogged with dust. Especially since you said this was an older laptop. It usually gets hot enough just when Windows starts to load that it shuts down from thermal protection. I would suggest getting a can of pressurized air, blow in from where the hot air leaves the laptop, you'd be amazed how much dust comes out of there. |
