Thread: Compaq Armada 1571DM problem |
Silver Member Username: Newtofta
Post Number: 200 Registered: Feb-07
| Posted on Sunday, March 16, 2008 - 05:45 pm: |
When i start the computer the screen shows tha amount of ram in it and says that it is ok.....then it goes to a black screen and says Non-System disk or disk error, replace and strike and key when ready. Have Windows ME disk but doesnt read it. Sounds like it want to boot from floppy but i cant get into bios to change boot process(its like there is no bios on it). Can someone please help |
Bronze Member Username: Annamouse
Post Number: 28 Registered: Aug-05
| Posted on Tuesday, August 26, 2008 - 08:39 pm: |
Go to google, search "compaq drivers", go to HP's site, put in your model, download "Computer Setup for Portables" under "Software - System Management" and run it to put the files on a bootable floppy. I had to run the setup .exe from a flash drive because it wouldn't run on my C drive. This gets you into "BIOS" of sorts. |
Post Number: 29 Registered: Aug-05
| Posted on Friday, August 29, 2008 - 03:41 am: |
"I had to run the setup .exe from a flash drive because it wouldn't run on my C drive." I believe that's due to RAWRITE.EXE needing FAT? I have a 1571DM also. I'd like to hear how your things turn out. |
