Thread: Bose vs. Klipsch |
Bronze Member Username: Dscrobe
Reading,
PA
Post Number: 86 Registered: Dec-05
| Posted on Sunday, January 27, 2008 - 05:20 pm: |
I purchased the Klipsch Groove PM20 multimedia 2.0 speakers. However, when I heard the Bose Companion 2 (this is a 2.0 system as well) at a visit to one of their stores, they sounded even greater than the Klipsch's. I had them put side by side at home and noticed the following. The Klipsch's provides for bass control, which Bose doesn't have. The Klipsch's had more base. However, when I asked myself which played so that I can truly appreciate the entire sound of the song I was playing, I chose Bose. Can't explain it, but the Bose just sounded more natural. I have noticed that Bose does not like to produce their specs and graphs. I got a very lengthy response from them when I approached them about it. |
Platinum Member Username: Project6
Post Number: 14630 Registered: Dec-03
| Posted on Thursday, January 31, 2008 - 11:15 pm: |
That is the only thing that matters, man. |
New member Username: Duke_19007
Post Number: 6 Registered: Feb-08
| Posted on Saturday, February 16, 2008 - 04:19 am: |
I agree daniel...Bose is the best...their philosphy is that people should eveluate the performance of speakers, by the way it sound, not based upon any arbitiary numbers.....well you can always take two different speakers with two different brands with same specs...but then, Why they sound different at same volumes..? So our ears are the best judge.....Bose Companion 2 are awsome..and if the portibility is not the requirement...Bose Companion 3 ROCKS.... |
Reading,
PA
Post Number: 90 Registered: Dec-05
| Posted on Saturday, February 16, 2008 - 11:40 am: |
Unfortunately, the speakers are for office setting and I think coworkers were getting annoyed at the bass. There is no bass control to adjust. So, I went with the Klipsch, which has a bass control. |
Gold Member Username: Gavdawg
Albany,
New York
Post Number: 1155 Registered: Nov-06
| Posted on Friday, June 06, 2008 - 12:28 am: |
bose speakers blow for the most part, but I do like the offerings they have for computers |
Platinum Member Username: Glasswolf
Wisteria,
Lane
Post Number: 12147 Registered: Dec-03
| Posted on Monday, August 04, 2008 - 03:06 am: |
honestly, after over 20 years in the audio industry I can tell you bose and klipsch are pretty must garbage, that sell based on name recognition. If you wnt some quality PC speakers, look at Logitech's higher end stuff. It's not so bad for PC speakers, although I still like my Martin Logans better  |
