Thread: Can't Get Game to Start From ISO Image file |
Bronze Member Username: Donshiv
Post Number: 35 Registered: Jun-05
| Posted on Tuesday, January 22, 2008 - 08:08 am: |
Hi. I got this game and it's an ISO image file. I mounted the iso using "poweriso" and then I installed it. Now that I've installed it, and I click on the mounted iso file, I can't play the game. When I click on the mounted iso the game menu comes up, then I press play game and then it says check to see if cd is in the cd-rom drive. What am I doing wrong here? Please help. Thanks. Using Vista by the way. |
Relevant Product Info
New member Username: Paulie0117
Cambridge,
Ontario
Post Number: 4 Registered: Dec-07
| Posted on Friday, January 25, 2008 - 09:01 am: |
You need to download the crack for whatever game you have mounted. Just use the same torrent name of the game and add the word -crack- and download it, and place it in your game directory, assuming you have already unloaded the game. Your game directory will be in C/Programs/(your Games title) copy and paste the crack there and when it says there is already one there would you like to replace it just click YES |
Post Number: 36 Registered: Jun-05
| Posted on Tuesday, January 29, 2008 - 08:32 pm: |
Thanks, I'll try it. |
Gold Member Username: Th3pwn3r
Post Number:...
Post Number: 6850 Registered: Jul-06
| Posted on Wednesday, February 13, 2008 - 04:22 pm: |
You have to use a virtual drive to trick your computer that the disc is in the disc drive. Look for Daemon tools and you'll be set. |
