Home > Message Board > Computers > Notebooks > HELP ME!! I MADE A BET!!
Author Thread: HELP ME!! I MADE A BET!!
Username: Dj_excite
Post Number: 140
to all tech gurus please find out if the dv5000t has pcmcia express and if a reg pcmcia card will work in this laptop regardless of the card to be compatible of vista or not.
Relevant Product Info
Username: Viller
Hope You didn't loose the bet
PC Card Slots: One Type II
Short for Personal Computer Memory Card International Association, and pronounced as separate letters, PCMCIA is an organization consisting of some 500 companies that has developed a standard for small, credit card-sized devices, called PC Cards. Originally designed for adding memory to portable computers, the PCMCIA standard has been expanded several times and is now suitable for many types of devices. There are in fact three types of PCMCIA cards. All three have the same rectangular size (85.6 by 54 millimeters), but different widths
Type I cards can be up to 3.3 mm thick, and are used primarily for adding additional ROM or RAM to a computer.
Type II cards can be up to 5.5 mm thick. These cards are often used for modem and fax modem cards.
Type III cards can be up to 10.5 mm thick, which is sufficiently large for portable disk drives.
As with the cards, PCMCIA slots also come in three sizes:
A Type I slot can hold one Type I card
A Type III slot can hold one Type III card or any combination of two Type I or II cards.
Post:
Username: Need to Register?
Password: Forgot Password?
Action:
Home > Message Board > Computers > Notebooks > HELP ME!! I MADE A BET!! [ « Previous ] [ Next » ]
