Thread: Sharing Wireless Internet Service!!!!Help!!!!PLZ!!!! |
Bronze Member Username: Cybermaster
Post Number: 88 Registered: Jan-07
| Posted on Thursday, November 22, 2007 - 04:20 am: |
Hello Friends, I'm Sharing wireless internet service with my friend. He live about two blocks down. I catch his signal using 24db high gain parabolic grid antenna. I could only run one wire from the antenna and that wire only goes to my computer. But there are two more computers in the house which cannot access the internet. What I wanna know is, is there a way to catch that signal with a wireless router or something? Basically what I wanna do is catch that signal with a wireless router, and then redistribute that signal in my house so that all the computers can access the internet. I don't know if this is possible. Also, the router must be USB because wireless adapter is USB. I would like your comments on this. Any help will be greatly greatly appreciated. Thanks. |
Gold Member Username: Donnie1973
Post Number: 1916 Registered: May-06
| Posted on Monday, November 26, 2007 - 10:22 pm: |
U can buy two routers that can be bridged. They connect to each other basicaly, and then the router in ur house would work of it. But I think u may be able to buy an access point and connect ur antenna in to that?? I have never done it, but might work. |
Post Number: 2447 Registered: May-06
| Posted on Friday, December 28, 2007 - 08:42 pm: |
yes that would work, but u can run the internet connection wizzard and make the one that gets the internet be the host, then set the others up to use that one a the gateway to the net. The host pc will give others IP addy's. Read in the internet setup wizzard. |
