Thread: Router Power and Location |
Bronze Member Username: Frank1203
Philadelphia, PA
Post Number: 78 Registered: Mar-06
| Posted on Wednesday, November 14, 2007 - 12:18 pm: |
Hi, I am in the process of remodeling my home and would like to access all of our computers wirelessly. I would think that the most easiest and efficient way to do this would be to install a router in basement where the cable comes in and split the signals from there. The problem is that that the basement has concrete walls and I am concerned about strength of signal to the second floor and speed. I currently have a linksys Wireless G router installed on our second floor and the speed is not that great even though it is situated much closer to the laptops. I have Comcast High Speed Internet. What can you recommend as far as Router location and signal strength? Are there more powerful Routers out there that might work better for me? |
Gold Member Username: Donnie1973
Post Number: 1809 Registered: May-06
| Posted on Wednesday, November 14, 2007 - 10:53 pm: |
If I were remodeling... I would put wiring in place from the basement to several locations in my home. Spots where u could add access points if needed. There are routers thet seem to penetrate better. I found that prosafe is a good one. In my experiences, the higher the better for them.. although I dont reccomend the attic. (heat) Cant hurt installing some cabling around the house too. Its cheap and easy. |
Philadelphia, PA
Post Number: 79 Registered: Mar-06
| Posted on Thursday, November 15, 2007 - 05:51 am: |
Thanks Dantetn, but I'm kkind of new at this and am not quite sure what you're recommending..when you say "put wiring in place from the basement to several locations..", I'm not sure what that means.. The idea of using wireless routers is to be wireless! Maybe what you mean is to have the cable running into different rooms of the house from the basement and connect a few routers at different points around the house? In other words - not just one powerful router in the basement, but maybe a router on each floor or in the hallway? I think I need some clarification if you don't mind. Also, do you recommend Wireless G or N? Thanks |
Bronze Member Username: The_cell
St.john,
N/a
Antigua
Post Number: 12 Registered: Jul-06
| Posted on Thursday, November 15, 2007 - 08:45 am: |
hi where i live a lot of wireless internet but i cant get on them what can i do to get on |
Post Number: 1835 Registered: May-06
| Posted on Sunday, November 18, 2007 - 12:36 am: |
yeah, by wiring, i meant whileur remodeling put some wiring in place... ya never know if u will need it. cat 5e wiring, a few jacks on each floor for wireless routers/access points. Just in case. Like I said, the higher the wireless devece, the better. I wouldnt put one in the basement if u have a 3 floor house. Central on the second floor if u want to only use 1 router. It should work. Wireless n is the newest. I have g in a 2 story house, it works fine for me all over. The range exteders work well. prosafe routers u can bridge off each other, in other words u dont need a cable for all but the master one. all u need is power. They are pretty powerfull, but 200 each. |
Post Number: 1836 Registered: May-06
| Posted on Sunday, November 18, 2007 - 12:37 am: |
if u are wanting to use someone elses wireless, u cant if they have it WEPed, but if not, and u get a good signal u can. |
Gold Member Username: Cartier1
Post Number: 1413 Registered: Feb-07
| Posted on Sunday, November 25, 2007 - 11:28 pm: |
dantetn u r here too hummmmmmmmm, since u know about this stuff . i have labtap with intelpro wireless . i have a linksys router b wireless. i did the connection / i can establish a a connnection only for a default network . but can not coonect with linksys . i can see the linksys network with a high bars but can not connect to it . i desabled my firewall still no success. thanx. |
Post Number: 1917 Registered: May-06
| Posted on Monday, November 26, 2007 - 10:23 pm: |
do u have a wirless b card in ur laptop? |
Post Number: 1416 Registered: Feb-07
| Posted on Monday, November 26, 2007 - 10:29 pm: |
i dont need it cuz my computer is wireless. i can connect now . but as long as i cancel my firewall. if i do i loose connection . |
Post Number: 1919 Registered: May-06
| Posted on Monday, November 26, 2007 - 10:39 pm: |
u have a built in wireless card. Sometimes u have to poke holes in ur firewall, but that is advanced. At least ur on now |
