Home > Message Board > Computers > Notebooks > Sony Vaio VGN-AR390E AC Adapter
Author Thread: Sony Vaio VGN-AR390E AC Adapter
Username: Sb052287
Dallas, Texas
Post Number: 52
My notebook, as described in the title, AC adapter has a beeping sound coming from the adapter and the green LED is not turning on. The Beep is repeated. When plugged intot the computer it shows to not be charging
Is there anything i can do to internally fix this problem? Or am I better off buying a new AC adapter?
Relevant Product Info
Username: Viller
Post Number: 10
Shea,
Wow a new one to me I have never had a charger for a laptop to beep at me
first check to see if its still under warrenty
http://esupport.sony.com/perl/select-system.pl?DIRECTOR=DOCS
if its not I would check into prices for a replacment on the net maybe ebay. it will be cheaper then buying directly from sony.
good luck
Post:
Username: Need to Register?
Password: Forgot Password?
Action:
Home > Message Board > Computers > Notebooks > Sony Vaio VGN-AR390E AC Adapter [ « Previous ] [ Next » ]
