Thread: Internet to laptop |
Bronze Member Username: Epidemic_wat
Clovis,
California
U.S.
Post Number: 19 Registered: Jun-07
| Posted on Friday, October 26, 2007 - 03:43 am: |
i just bought this new sony laptop but have no internet at home., what do i need to buy to get wireless internet to my laptop at home? |
Relevant Product Info
New member Username: Cornerstone137
Post Number: 8 Registered: Oct-07
| Posted on Friday, October 26, 2007 - 08:12 pm: |
Ruben, do you already have some type of high speed(cable or DSL)? If so, then you can buy a wireless router. The router will have one jack for input, and several for output. The ethernet cable from the modem needs to be plugged into the router input. The you will need another cable to go from one of the router outputs to your main computer's ethernet card. The laptop will automatically detect the wireless connection. and should connect automatically. I would suggest that you add security to the router. There is a good article about security at: http://compnetworking.about.com/od/wirelesssecurity/tp/wifisecurity.htm Tim |
Clovis,
California
U.S.
Post Number: 22 Registered: Jun-07
| Posted on Saturday, November 03, 2007 - 04:25 am: |
no i have no high speed internet. i have no internet at all ? |
Gold Member Username: Donnie1973
Post Number: 1656 Registered: May-06
| Posted on Monday, November 05, 2007 - 08:39 pm: |
u have to get dsl or cable internet service from a local provider. Or hope a neighbor has wireless u can get. |
Bronze Member Username: The_cell
St.john,
N/a
Antigua
Post Number: 11 Registered: Jul-06
| Posted on Thursday, November 15, 2007 - 08:39 am: |
hi where i live a lot of wireless internet but i cant get on them what can i do to get on |
