Home > Message Board > Computers > Sound Cards > Have no audio
Author Thread: Have no audio
Username: Aussie_99
Post Number: 15
My computer doesnt play audio. I tired using WMP and the sound doesnt work but the picture is fine. When i play music this message comes up ""Windows Media Player cannot play the file because there is a problem with your sound device. There might not be a sound device installed on your computer, it might be in use by another program, or it might not be functioning properly.""
Username: Tombrown199
Post Number: 11
i have same problem , and need some help too
Username: Project6
Post Number: 14513
Ever solve this problem?
Username: Amityadav6100
It seems that your pc doesnot have sound drivers or Drivers may be corrupted.
check device manager for it , if you see yellow mark over Audio and sound then
install Audio drivers from your motherboard cd .
Username: Eatisa
Post Number: 16
Yes, you should install the CD which comes with your Motherboard because it wll be compatible with it. Try it and I think your problem will be fixed.
Post:
Username: Need to Register?
Password: Forgot Password?
Action: Upload Upload Image
Home > Message Board > Computers > Sound Cards > Have no audio [ « Previous ] [ Next » ]
