Home > Message Board > Computers > Desktops > Archive through November 26, 2007 > How To Fix Windows Update [BITS/AU]
Author Thread: How To Fix Windows Update [BITS/AU]
Username: Mekongdelta69
Grew up in Brooklyn an...
Post Number: 53
{Since there's no software section on ecoustics, this seems as good a place to post this as any. I've posted this in the several forums, which have helped me out, so maybe somebody here can use it too..}
This is for anyone who's having trouble with WU (BITS/AU):
http://castlecops.com/t106642-How_To_Fix_Windows_Update_BITS_Newly_Edited.html
-or-
http://www.castlecops.com/postlite106642-.html
[I wrote it -- I would have posted the entire set of instructions here, but I wasn't sure if I could upload the Zip file with the Registry fixes on this N.G., so anyone could subsequently download it. However, the necessary File ready for downloading, along with the lengthy instructions, are all located at the above link.]
If the above link doesn't work, go to:
Click "Forums" right below the Castlecops logo, then go to the "General Computer Problems" Forum (2nd one down), click on it and look for the Topic called:
"How To Fix Windows Update (BITS/AU)".
[As of THIS writing (8/14/07 10:25 AM EST), it was on the 1st page (on top) and the 'Last Post' was made on Thu. Aug. 9, 2007 at 6:31 AM]
If you're not a member and want to register for a free account, go to:
[Look on the bottom of the Login box on the right side and click where it says:
"Click here to create a registered account"
(and follow the instructions from there).]
Hope it helps somebody here (it sure seemed like it did at CC).
[Two and a half years later and it's received over 128,100 hits,
over 12,860 downloads and hundreds of responses, suggestions, additions, questions and "thank you's," so I guess it's helped a few people at least...]
Home > Message Board > Computers > Desktops > Archive through November 26, 2007 > How To Fix Windows Update [BITS/AU] [ « Previous ] [ Next » ]
