Home > Message Board > Computers > Notebooks > Problem with connecting to the intern...
Author Thread: Problem with connecting to the internet w/o using my wireless router
Username: Ferrarifire
Post Number: 29
i am tryin to connect straight to the net with out using my wireless router but when i plug the ethernet wire into my laptop it does nt work.
Relevant Product Info
Username: Donnie1973
Post Number: 639
You need to check your connection properties. Also, make sure you your cable is good
Username: Wojopro
Summerville, SC
Post Number: 288
Are you connecting through the router or directly from the modem?
Post:
Username: Need to Register?
Password: Forgot Password?
Action:
Home > Message Board > Computers > Notebooks > Problem with connecting to the intern... [ « Previous ] [ Next » ]
