Home > Message Board > Computers > Desktops > Archive through November 26, 2007 > CPU USAGE 100 % ALL THE TIME
Author Thread: CPU USAGE 100 % ALL THE TIME
Username: Bleedingstar
Post Number: 10
WAAAH. i need help. what am i going to do? the cpu usage of my pc gets 100% always even though there's only one application open. and the pc gets lag all the time. i tried scanning the pc (the anti-virus that i am using is kaspersky), and it says that my computer is virus-free. this thing makes me really crazy. haha. i need help.
should i reformat my computer?
Username: Nickelbut10
Post Number: 125
Go to Start, Run, and type MSCONFIG then press OK. Go to the Startup tab and uncheck all the applications except for your antivirus. Press OK and then Yes to reboot. Sounds like you may be over loading your system with processes running in the background. Cheers.
Username: The_image_dynamic
San Diego
Post Number: 2619
It is more than likely a corrupt or incomplete .avi file that Windows is trying to analyze over and over to attain its properties. Here is the fix:
1. Click on Start, then run. In the "Open:" box type in "regedit" without the " "
2. Go to HKEY_CLASSES_ROOT\SystemFileAssociations\.avi\shellex\PropertyHandler
3. Delete the "Default" value which should be "{87D62D94-71B3-4b9a-9489-5FE6850DC73E}"
Post Number: 11
i already unchecked the applications on start up tab of msconfig, it helped but there are still moments that the cpu usage goes up. and still the pc seems to freeze (and the sounds still lags) everytime i open an application esp. if it is the mozilla firefox web browser that i opened.
San Diego
Post Number: 2659
I told you what to do Trina...
Username: Kngsze
Post Number: 18
I have seen this before and it is possible that a file called "msi.dll" is causing the problem (this is part of the WinUpdate). Load Task Manager and see if "svchost.exe" is raking up the CPU, if so, this is your problem.
A fix was released by MS, you can get it from WinUpdate
Username: Moey_g
Sydney
Australia
Post Number: 115
time for a Format
Post Number: 13
the default value is very different from this one "{87D62D94-71B3-4b9a-9489-5FE6850DC73E}"
i already checked the "svchost.exe".. no it doesn't have to do with the cpu usage of my pc
Home > Message Board > Computers > Desktops > Archive through November 26, 2007 > CPU USAGE 100 % ALL THE TIME [ « Previous ] [ Next » ]
