Home > Message Board > Computers > Desktops > Archive through November 26, 2007 > HP Pavilion a767c recovery cd's
Author Thread: HP Pavilion a767c recovery cd's
Username: Tetio2004
Post Number: 41
hi does anybody own a hp pavillion A767C PC.?
I replaced my harddrive and I am in desperate
need of the recovery cd's. May be you can make me a copy. I will really appreciate it.
thanks.
Username: Donnie1973
Post Number: 618
Why not just add win xp and get on the net to find your drivers?
Username: Tetio2004
Post Number: 42
Hi Danteth I Have tried that, but I only find updates drivers. or upgrades drivers I never could find the acual drivers. you know the sound, video, netwok drivers etc...
Post Number: 620
Hmmm... You can find them. Go to HP.com and look for your model. They should have all drivers in a list.
Username: Tetio2004
Post Number: 43
Hi thanks, yes I did that they have drivers, but they r uptade drivers which means that you have to have a previous older drivers already loaded to use an update drivers. I was hopping that somebody have a working pc to make a set of cd's. at a low cost.
Username: Nickelbut10
Post Number: 127
HP do not make their own motherboards. Open up the case, check the Make and Model of your motherboard. Search it or go to the manufacturers site of the motherboard and download the drivers from there. Cheers.
Username: Tetio2004
Post Number: 44
That is a good idea!!!Iwill try that, I've done it in the past.
thanks so much
Greetings
Home > Message Board > Computers > Desktops > Archive through November 26, 2007 > HP Pavilion a767c recovery cd's [ « Previous ] [ Next » ]
