Thread: Speakers for computer |
New member Username: Lkelly75
Post Number: 1 Registered: Jul-07
| Posted on Friday, July 13, 2007 - 11:02 pm: |
I just purchased a set of Durabrand 3 watt speakers from Wal-Mart for my computer. There was no programs or disk with the speakers and I cannot get them to work with my computer. I really need some help, did I purchase speakers that will not work with my laptop? Thanks in advance. |
Silver Member Username: Stefanom
Vienna,
VA
United States
Post Number: 781 Registered: Apr-06
| Posted on Wednesday, July 18, 2007 - 03:08 pm: |
Generally you just pop them into the audio/headphone output of your laptop, and they work. Check that you haven't plugged them into the mic out or anything. And no, they don't need drivers. |
Silver Member Username: Nickelbut10
Post Number: 128 Registered: Jun-07
| Posted on Thursday, August 02, 2007 - 02:45 pm: |
Also check under Start, Control Panel, Sounds and Multimedia that all your sound properties and speaker properties are turned up. Make sure first their not muted. Retail Laptop's sometimes come with the onboard audio turned way way down if not all the way down. |
New member Username: Tradestead123
Post Number: 3 Registered: Mar-09
| Posted on Sunday, March 08, 2009 - 11:00 pm: |
i have the similar problem as you , i bought a speaker for my laptop , but it can not work. so i use it on another computer it works all right, but i can not find anything wrong with my computer ,so i want to know what is wrong? |
