Thread: Symantec Antivirus |
Bronze Member Username: Nicdan
Post Number: 13 Registered: Oct-06
| Posted on Tuesday, July 10, 2007 - 07:37 am: |
Hi can someone help, i have the latest version 10.0.1.1000 and appears to be working well but if i try to copy and paste from a web site to a word doc or excel it jams up my computer. the only way i can get rid of it is to control alt delete. ......any ideas Dave |
Relevant Product Info
Bronze Member Username: Slntdeath
Post Number: 16 Registered: Nov-06
| Posted on Wednesday, July 18, 2007 - 03:24 pm: |
Well, First, Be sure it's your antivirus. Try uninstalling Norton, (Or Disabling) And turn on Windows Firewall for the time being, Then try to copy and paste again. If it's indeed your AntiVirus, Either contact Symantec, Or use an alternave, Such as AVG Internet Security |
Silver Member Username: Dj_excite
Post Number: 109 Registered: May-04
| Posted on Saturday, September 01, 2007 - 09:04 pm: |
I recomend AVG, i had norton, and mcafee, mcafee is a pain, norton was a bit better, AVG works the best and is really simple, keep it updated and u should be fine, and also doesnt use too much of ur computer. best of all ITS FREE!!  |
