Thread: The system unit gets noisy. HELP! |
New member Username: Bleedingstar
Post Number: 3 Registered: Jun-07
| Posted on Thursday, June 21, 2007 - 04:29 am: |
kindly help me. the system unit gets noisy after a few minutes of booting.. it seems to whistle everytime i use the computer. what do you think is the problem? need help. thanks. |
Relevant Product Info
Bronze Member Username: Kngsze
Post Number: 16 Registered: Mar-06
| Posted on Friday, June 22, 2007 - 07:25 am: |
Could be a dirty/dusty fan, clear any dust etc. Also check your BIOS settings. On most modern PC's you can specify, at what temp the CPU fan spins up. Aside from that, it could be a faulty fan, or just a few loose screws |
Post Number: 5 Registered: Jun-07
| Posted on Sunday, June 24, 2007 - 03:09 am: |
what is the ideal temp for CPU fans? |
Silver Member Username: Motomattic3
Post Number: 567 Registered: Oct-06
| Posted on Monday, June 25, 2007 - 12:02 pm: |
It realy depends on what chip you have this site should help you out http://mybroadband.co.za/vb/showthread.php?t=46670 |
Post Number: 6 Registered: Jun-07
| Posted on Thursday, June 28, 2007 - 12:11 pm: |
is it alright if the speed of my fan is inconsistent? |
Bronze Member Username: Dj_excite
Post Number: 68 Registered: May-04
| Posted on Monday, July 09, 2007 - 07:17 pm: |
it depends at certain times the fan will speed up by itself when u use certain applications that require more than usual. then it will be inconsistant to keep the computer cool. when i run heavy applications on my dell the computer sounds like its about to take off, trying to keep its self cool. but that whistle shouldnt com i think your fan or fans are just dirty. |
Post Number: 9 Registered: Jun-07
| Posted on Tuesday, July 10, 2007 - 11:13 am: |
i tried cleaning the fan.. the sound vanished but after a day or two, it started whistling again.. |
Silver Member Username: Stefanom
Vienna,
VA
United States
Post Number: 770 Registered: Apr-06
| Posted on Tuesday, July 10, 2007 - 01:17 pm: |
Get better fans? |
Bronze Member Username: Slntdeath
Post Number: 19 Registered: Nov-06
| Posted on Thursday, July 19, 2007 - 08:16 pm: |
Trina, The most likely cause of the noise is bad fan bearings. If you stop the fan, Is the whistling still present? If so, It could be your Power Supply Fan. In which case it's probably better to purchase a new Power Supply. As for your inconsistent fan speed question, As kirmoney stated, Some applications require more from your CPU and thus causing it to produce more heat. The higher strain on the CPU will automatically trigger the fan to increase RPM. A slight variation in fan speed (For example, 2300-2375RPM) Is extremely common. |
New member Username: Cooltech
Post Number: 4 Registered: Dec-07
| Posted on Saturday, December 08, 2007 - 12:21 pm: |
It could be the fans/power supply. |
