Thread: HELP stero speakers to pc |
New member Username: K30wn
Post Number: 1 Registered: May-07
| Posted on Thursday, May 24, 2007 - 06:04 pm: |
HELP, my stero speakers have no aux connection, is there any other way to hook them to my pc. |
New member Username: P4s
Post Number: 4 Registered: Jun-07
| Posted on Tuesday, June 19, 2007 - 12:48 am: |
no aux connection as in? is it already hooked up to something else and you want it to be connect to ur PC? |
Post Number: 2 Registered: May-07
| Posted on Tuesday, June 19, 2007 - 07:47 am: |
there connected to my stero. |
Post Number: 10 Registered: Jun-07
| Posted on Tuesday, June 19, 2007 - 07:50 am: |
okay. so i presume it is connected to your stereo system and you want your PC to be there at the same time |
Post Number: 3 Registered: May-07
| Posted on Tuesday, June 19, 2007 - 12:34 pm: |
is der any way |
Bronze Member Username: P4s
Post Number: 11 Registered: Jun-07
| Posted on Wednesday, June 20, 2007 - 04:39 am: |
yeah. u'll prolly need a couple of splitters and also a Y-adapter |
Bronze Member Username: Dscrobe
Reading,
PA
Post Number: 83 Registered: Dec-05
| Posted on Friday, January 18, 2008 - 09:51 am: |
Did you get fixed Ciaran? |
